1970 duster wiring
Electrical and Ignition
  1. Bills70
    Bills70 Well-Known Member
    439
    36
    Jan 30, 2010
    cadillac michigan
    Local Time:
    6:51 AM
    does anyone have any idea were or what these wires go to? plug with 4 yellow wires are right behind radio and the other one is to the right of radio looking from below and the green ones are down buy were dash harness connects to rear harness buy dimmer switch.
  2. 70Duster440
    70Duster440 Well-Known Member
    2,606
    196
    Jan 8, 2006
    Washington
    Local Time:
    4:51 AM
    Top connector provides power and lights to the radio. Orange is always instrument lighting. Looks like someone removed wiring from one side of the connector. Black angled plug with yellow wires for a dash mounted map light light/switch. Probably never had one so the connector is unused. I'm going to say the bullet connector with yellow wires is for the door jamb switch.
  3. Bills70
    439
    36
    Jan 30, 2010
    cadillac michigan
    Local Time:
    6:51 AM
    the bullet connector color is light green not yellow! I found the two yellow wire for door jam switch already. do you think the bullet connector and green wire's could be for headlight delay?
    I am glad I ask what the wires went to because I had the wrong plug plugged into radio. for some the plug with missing orange wire was plugged into radio wire already and I was not aware of it so I put correct plugs together. but now I need to know what the plug I had plugged into radio goes to. I sent pics of radio wires together also
  4. JoeSBP
    JoeSBP RLTW!
    1,124
    546
    Jun 16, 2015
    NC
    Local Time:
    7:51 AM
    Do you have the heater switch and lights plugged in?
  5. Bills70
    439
    36
    Jan 30, 2010
    cadillac michigan
    Local Time:
    6:51 AM
  6. 67Dart273
    67Dart273 Well-Known Member
    38,632
    6243
    Oct 14, 2010
    Idaho
    Local Time:
    4:51 AM
    OP don't you have a service manual? The yellow is dome lighting. If you are referring to that, it's likely courtesy lamps or map light system
    That connector appears "curved"? That hooks to the time delay I think EDIT looked it up map light connector
    Start with page 8-139 of the 70 Plymouth service manual
  7. 70Duster440
    2,606
    196
    Jan 8, 2006
    Washington
    Local Time:
    4:51 AM
    Bill, Remember that connectors found under the dash may be unused - they may never have been connected to anything for accessories your car did not come with. Like I said, I believe the black connector was for a map light and switch. Some earlier Valiants had map lights on the dash. (‘70 Dusters were “Duster - Valiants”) Mine was not equipped with a map light.
    The gray connector with red, black, and yellow wires was for a headlight on reminder buzzer. Also likely not used.
    Look at the two connectors in the middle of this diagram.
  8. 70Duster440
    2,606
    196
    Jan 8, 2006
    Washington
    Local Time:
    4:51 AM
    I believe you’re right on the light green wires to the bullet connector. It connected to a delay relay - also not used. At least it wasn’t on my ‘70. You’ll notice reference to the map light accessory in this drawing too.
  9. Jarrod Franklin
    Jarrod Franklin New Member
    3
    0
    Jul 8, 2018
    Bloomington, IN
    Local Time:
    7:51 AM
    Hi, does anyone have the diagram that shows what each of the wires going to the 9-pin round main plug for the instrument panel go to? I am referring to the round plug that attaches to the pins of the circuit board near the speedo. Mine is a 70' Duster. Thanks.
  10. 67Dart273
    38,632
    6243
    Oct 14, 2010
    Idaho
    Local Time:
    4:51 AM
    You need to bomb over to MyMopar and download a/ some factory shop manuals. You can easily follow the circuit board traces of the cluster. If you have trouble with that post a good clear photo of the front and rear of the cluster and we can guide you through
    If you have not, read this thread on PC board repair:
    Printed circuit pins repair
  11. Jarrod Franklin
    3
    0
    Jul 8, 2018
    Bloomington, IN
    Local Time:
    7:51 AM
    Thanks, that other thread was very helpful. Will work on it accordingly.
