Double checking before I start troubleshooting.To check for alternator charging I can put meter on battery with motor running unplug field wire and jump field to neg side of battery to make alternator charge correct? If its charging then go to regulator not sure how to check that? Everything is stock was charging fine so don't think its a wiring problem any help appreciated!
No. You're mixing things together.
Terms
Battery charging: This is indicated on the ammeter in the dash. (The is gage labeled alternator). If the car is running and the ammeter needle points Discharge, then the car is running on the battery and something is wrong with the alternator.
If the needle is centered or pointing somewhat to charge, then the battery is recharging or recharged and nothing is wrong.
Alternator output: People commonly call this alternator charging, but that can get confusing when troubleshooting. If the alternator is not producing enough power, or not any power, then this is what you want to troubleshoot.
Quick troubleshooting if the ammeter has been showing discharge while running:
1. Charge battery.
2. With engine running check voltage of battery positive to ground, and then alternator output to ground. Make sure the multimeter is set to DC Volts.
It should be the same at both locations, and should be 13.9 - 14.8 V. If its less, increase to fast idle to see if that changes anything.
3. Test whether its a problem in the regulator or the alternator.
a. Disconnect the green field wire.
b. jumper that field terminal on the alternator to ground.
c. Check alternator output voltage (stud terminal to ground) and the ammeter.
^^^This test bypasses the regulator's internal control, full fielding the alternator. If the alternator is working sightly revving the engine will cause the voltage to increase. Be careful when increasing engine rpm as voltage will climb.
4. If the problem is not in the regulator, make sure the field is getting power. Check the voltage at the blue wire (back probe the connector).
If it is at system voltage, then most likely an alternator problem.
The tests may make more sense if you read through the 'how it works' here
Identifying Chrysler Alternators (1960-1976)
