jakeborg69
T
That’s exactly what I’ve been doing. I just don’t have much day light after work ends to be out there. I still drive the car every day. It’s my daily driver. So far I’ve been tracing out all the relevant wires and isolating them. Besides the weird push button jumper someone’s wired up everything looks good. I still need to get under the car and trace out the wires too and from the starter. I’ll post picture updates tomorrow with what I’ve found so far.
The first clue - or question - should have been "what is that extra wire doing on the relay's solenoid terminal?"
You have two choices in tracing the wires.
1. Unwrap everything and physically follow it. Draw out what you find.
2. Use your multi-meter to identify what connects with what.
In reality, the best method is a combination of these. This what I and some others were trying to get you to do up at the top.
a. Identify and draw or mark all of the components and connections of the relevant circuits.
b. Use the multimeter's voltmeter and resistance functions as appropriate to figure out what connects vs what should connect.
c. Then hunt down the circuit where connections should be getting made and aren't.
Seems like you are struggling with how to make use of the multimeter. I tried to give you a very step by step in post 13 to determine if power is making it from the key switch to the starter relay. Should not need a second person. Place the meter where you can see it and run the test leads as needed.
Two more tips.
a. When checking for resistance and continuity, disconnect the car's battery.
b. Remove the negative cable first, and while you're there clean the contact surfaces of both battery cable clamps and terminal posts.
