1971 dart sb disk to bb disk ?
Swap to BBP brakes or use wheel adaptors. What's wrong with the SBP brakes?
is there a way on the front to go to big bolt ? thanks for any help ?
Yes there is a way. I swaped my 4 piston Kelsey Hayes sbp disks for Willwood bbp disks but there is a catch. Willwood only makes a kit to go from sbp drums to bbp disks. All you have to do is swap the sbp spindles for a sbp drum and add the lower ball joint for the sbp drum (about $20.00 from Rock Auto). I also found that I wanted more stopping power so I added a master cylinder from Willwood along with a adjustable pushrod from Stainless Steel brake corporation and a adaptor from 4 bolt to 2 bolt to mount the new master cylinder (all available from Summit)
Good Luck!
:toothy5:thanks for the info im putting an 8.8 in the rear i want to put skinnies up ft . does any one make skinnies in sbp ? found some
Centerline used to make them as I have a set on my car. They're 15 X 3 or 4....something like that.....true pizza cutters!
