Rocky A
Im asking 15K OBO car is located in Louisville,Ky
This car is originally a slant 6 car but has been completely restored every nut and bolt has been turned the car is 95% done all it needs is headliner replaced and a seat wrap for the front seat and both side mirrors had the car finished and ripped the seat car has all new stickers and call outs has a 340 .30 over completely redone car makes good power the bottom of the car has been completely painted and worked new passenger front floor pan new carpet everything works on the car ENGINE- 1970 block with J heads mallings oil pump arp rod bolts stock stroke 750 dual pump holley flat tappet cam stock rods TRW pistons high compression lunati cam all freshly rebuilt all new clevite bearings.Transmission- 727 Torqueflite all freshly rebuilt with 2500 stall converter Rearend- 8 3/4 open brand new dr diff 30 spline axles with green bearings with brand new drum brakes all freshly rebuilt all new hardware the front brakes are disc brake this car is big bolt pattern you have any questions message anytime thanks
