1972 Daddy Daughter Duster
There is also a Sunday cruise at draft picks, on N Aurora road just west of RT.59 12:00 to 3pm haven't been there yet so not sure if it's any good.
Hi Mike,
I've heard about the draft picks cruise, but haven't made it there yet either. Gonna try get back to Braconis tomorrow after work for a slice. Typically a smaller low key event. But nice just the same. Maybe see you there?
Take care,
Pat
My daughter and I hit a local cruise night when I got home from work one night last week last week. Spur of the moment, had a great time. And to top it off she won a trophy with her Duster. Totally unexpected! You couldn't have pried that thing away from her all the way home LOL!
I closed shop and snapped a few pics from my office window after the crew left for the day. Then swung by the house to pic up my daughter.
My little Gear Head Angel!
The proud girl! Just doesn't get any better than that.
Take Care Folks,
Pat
Well, finally got back in the garage this morning to knock out a few more tasks, i.e. pesky rear main seal leak and harmonic balance. next weekend I'll get the tranny out and fix a leaking front seal, and anything else that I can.
Kudos to your daughter on the trophy. Did they add points for the big smile?....should have.
We all hate those pesky leaks. Just replaced the ever so slightly dripping rear main on the silver Duster last month. I tried a seal Mancini sells that has two thin rubber "o ring" style seals on each side. So far, so good.
Update:
Mostly a "Daddy" project now that both girls have jobs for the summer. Though they'll help out when they're able.
They both had to work, so here's how I spent Father's Day Morning..... Actually everything came out pretty smoothly considering I did it solo. Took about 2 1/2 hours. Though I must admit, the transmission sure seems a whole lot heavier than they did when I was a kid dropping them in the driveway with a floor jack and blocks of wood! LOL Will definitely try to find someone to give me hand getting the tranny back in when the time comes!!!
Guess what I forgot to do...?
Here's a hint! LOL
Not good.... :-(
Just a quick update on our build. While the girls haven't been as involved due to school, friends and having their driver's licenses :O ! They are now asking when/if they can take the Duster to school! Been slow going but we've made a bit of progress. I replace the front pump seal, gasket and bushing along with the rear seal in the 727. And got it and new 3500 Converter back in the car thanks to the help of an old HS Gearhead Buddy on mine. (Damn near killed ourselves getting it in! LOL) Got the new rear main seal on the 340. Just need to get the oil pump, windage tray and oil pan bolted back in place.
This past weekend I got sick of idly looking at the car while waiting for warmer weather to arrive so I decided to bring the work inside. Pulled out the roached tail light assemblies to repair and refurbish them. So actually felt a little bit productive!
Be well folks,
Pat
The old seals weren't actually sealing anything!
One of the housings was somehow melted/warped?
But a little time with my heat gun and putty knife got it pretty close enough for my purposes.
Cleaned them up a bit and ready to proceed with the repairs (Broken mounting tabs, loose sockets etc) the some fresh paint. ;)
Note broken tabs and melted/misshaped housing on right side.
Heated the melted housing with a heat gun and pushed out with spoon to shape. Not perfect but good enough for my Hooptie!
Used POR15 Epoxy Puddy and JB Weld to form new tabs. I could've ground the finish smoother but just aren't that concerned about it for our application.
Overall, pretty pleased with the finished, low-buck, results.
Hit the inside of the housings with rattle can "Chrome" and it really brightened them up. Should definitely throw a bit more light than before.
The girls and I opted for Semi-Gloss black to tie then in with the black Go-Wing and future black striping kit.
Before
After
Hey Folks,
Just another update on the the project. Both girls are officially high school seniors now (hard to frigging believe!) and working to earn/save some money for college. So it's pretty much a Daddy project LOL!
Made some progress in the past few months:
Got the transmission back in the car and replaced the transmission and motor mounts.
Put the oil pump, windage tray and pan back in.
Clean up the filter adapter and got it in before bolting the headers back in.
Kicked off Father's Day in the garage by getting the headers bolted up.
Will be getting the pulleys, fan, radiator back in this weekend. Then need to recheck/torque all the fasteners to make sure I didn't miss anything. (In my haste..Failed to tighten the filter adapter last time and spewed oil upon start up LOL!) and hope to fire it up by the end of the month. Fingers are crossed the a) it starts, b) it doesn't leak and c) the transmission works!
Happy that the car is getting close to running again.
Be well,
Pat
Just adding a little update to the thread. The girls are 18 now and will be heading off to college in the spring. So it'll be pretty much a Daddy/Mommy project moving forward. LOL!
For the first time ever the Duster is leak free! Crazy to no see oil and transmission fluid spots on the garage floor. The trans ran great all summer and I absolutely love the new 3500 series torque converter.
After our last spirited drive, "The Boss" told me the car is running better than ever, and I had to "get some f'ing brakes on this thing!" So, obviously I had no choice but to heed her command.
Been eyeballing this Wilwood 11023 kit for awhile and finally pulled the trigger. Will be running new lines front to back, new master cylinder and rebuild rear drums.
Pat
Starting to dig into the project after Christmas. Thanks to some input from fellow FABO members I was able to procure most of the necessary components for the job. Pulled off the front drums, de-greased and took off the rust from the Spindles, CA's etc. Then hit them with a few coats of POR15. Nothing show quality here, just protecting parts.
Got the adapter brackets mounted onto the drum spindles. Other than drilling out a threaded bolt hole to 1/2 inch (pointing to in in pic 1) and using a floor jack to load the suspension in order to line up the holes for the steering linkage, no fuss no muss.
Drill out this hole with 1/2" bit
Use floor jack to line up holes for steering linkage
Studs in hubs
Used the rim to hold the hubs in place so I could get the 70lbs torque required.
Assembled the hub/rotor assemblies .
Packed the bearings and pressed in the seals.
Assembled hub
Assembly on the spindle.
I must say, this has been one of the simplest, straightforward mods I've done so far. My first impressions are very favorable !
The hardest thing of the whole installation was torquing the Torx head bolts to spec. Two trips the the store and 4 trashed T40 bits later, I got it done. LOL!
Got the hub assemblies torqued to spec and Loctited. Froze my a$$ off in the garage but got the calipers mounted. Test fit the Centerlines which fit with room to spare.
Gonna remove the old MC and Brake Lines front to back this weekend. Will update with more pics and trials/tribulations and things progress.
Steel wooled the surface rust and threw a coat of POR15 on the tank just because. Will need to pulled it out when I repair the rusted spare tire well.
I have been feeling motivated these last few months. Mainly because I'm feeling like a lot of the repairs I've been putting off have, or are getting done. While we're never really done with our cars, I'm seeing the light!
Be well folks
Pat
