1972 demon
There should be a small tag on one of the bolts that holds the back cover on and the ratio should be on it 2:76 or whatever, it's probably a little 7 1/4'' rear end, and it's not much use to you if you are going to put some power in front of it anyway.
The gear could be from a 2.76 to 3.55
Every 7.25 I have ever had 3.23
my 73 225/6 3 speed 7 1/4 had 2.76 gears, theres a tag right here. if you are going to do a build thread you should post all your pics here
