Why isn't it a stepside?
Sorry Gary, you are incorrect. The steering boxes on the earlier trucks were on the inside of the frame. The later truck on the outside. I have an 83 D150 chassis that the steering box is in the same place. I forget when they changed it, but that chassis is not a 72. Neither is the sheet metal.
I'm with you fellas...smells like a dirty diaperfullashit fullashit fullashit fullashit
I thought Concept Cars and Prototypes did not have a vin to keep them from being sold to the public?
I know the 55 Ranchero I have on the hill that you looked at has a VIN and it has four additional digits on the plate that are not supposed to be there. The last digit is a p. Ford confirmed that there was 6 prototype Rancheros made in the Dallas plant and that is where mine came from but I have never been able to confirm that it is one of the 6. It was a production vehicle overseas in 55.
Absolutely outstandingly beautifulmous...I would take it even if it was a pedal truck..I could flintstone it...those were the days
I apologize for being wrong on it being a late 70's truck, but can you please explain the anti-sway bar or tell me where I could get one. it seems like only late 80's trucks had that pieceIt's definitely a 70's Cab at the very least, may not be early 70's, but its 70's for sure. So is the bed and doors.
Starting in 1981, they changed the roof design (square back instead of rounded), and added an additional body line on the fenders, doors and quarters. That's how you can tell all of the sheet metal is 72-80 Early style body parts instead of the later 81-93 style body parts.
Also, the frame/Front Crossmember doesn't have Body Mount Holes in it (there would be 2 holes, side by side in the middle of the crossmember if it was a newer frame), so that tells you its an early 70's frame (pre-75). Early 70's trucks had the Core Support Body Mounts on the Outboard Mounts on the frame. This caused problems with cracking in the core support due to flex, so sometime around 74 they moved the body mounts for the core support inboard to the Front Crossmember. But Dodge never removed those Outer Mount Brackets from the frame (even up to 1993) even though they were never used again beyond 1974-75.
Nope72's had sway bars mainly big block trucks but I have had two small block trucks-72that also had themI apologize for being wrong on it being a late 70's truck, but can you please explain the anti-sway bar or tell me where I could get one. it seems like only late 80's trucks had that piece
where did the sway bars connect to? I'd love to get my hands on oneNope72's had sway bars mainly big block trucks but I have had two small block trucks-72that also had them
Yes I totally agree I mean come on a 67 383[in 72] and 'super bee'disk brakes=didnt happen,its a morph..not a factory prototype,probably some dude took a city truck[notice white paint on firewall] and morphed a 383 from a stationwagon,aint sure where he came up with the superbee concept,painted it red,either put the decals on the doors or took doors off a another truck,built some 'racks' for the bed...only thing rare is that it's never been seens before =cause they never existed from the factory,just imagine what the front clip is gonna look like prob has a 6pk scoop and a go wing and a factory tach mounted in the mirror....this is somebodys botched abortion nightmare..nothing more=junk,or parts..I do not believe any of it,I know MA MOPAR did some weird sh#t from time to time but not this,only 'prototype for this trk was for the gas co...the rest is someone else's imagination...I still think.... fullashit fullashit fullashit fullashit
If that was a real prototype "big red truck" in 72 it would be in the same class pilot cars. It would be worth 6 figures. Some of yall will believe anything.
