[WANTED] 1973 Dart 340 Sport K Member to 340 Engine Mount Bolts!
Pale340
Pale340
Huntsville, AL
Rating - 0%
0   0   0
I can't believe I have to ask this, but I am tired of trying to find these bolts. I need the Bolts, nuts, and washers that mount the engine mount to the K member. I have called all sorts of restoration companies for Mopar and no one sells those long bolts. Anyone have any source I can check with to get these? I checked with Fastenal and after several attempts they just cannot get the right ones. Any help here would be greatly appreciated. Thanks.
Try a wanted add or look at part cars in classifieds, possible all the same for 73 & up all engines, ask seller for both size and length & compare to your size.
Here’s the best advice I can offer check your local junkyards for any v8 small block powered,
Aspen
Volare
Diplomat
GranFury
Mirada
Magnum
Of 1980 to 85 model years that looks unmodified these models use the bolts you need. The most important thing to remember is to back the nut off don’t turn the bolts it ruins them, it’s a crappy job but probably the only way you will get some. Good luck.
Sinister.
a grade 8 bolt would be just fine. Get ones that have the correct shoulder length and if necessary cut the treads (with a hack saw) to get the correct overall length. Cutting bolts is very common in building race cars.
This guy sells them I bought 4 from him bolt nut with washer attached jeff@amsnos.com
