Builderguy
Is the section of the manifold that goes into the exhaust pipe, larger on a 340 than a 318? If not, I will just run one of the pieces I have.
My concern is that the manifold section going into the pipe is a bit smaller than the exhaust pipe. I guess I could cut the pipe down a little to tighten it up before it bottoms out.
So when I put them together, it is not a very tight fit.
The two right side manifolds I have are basically the same outlet size.
