1974 Dodge Dart Sport rebuild
Is the section of the manifold that goes into the exhaust pipe, larger on a 340 than a 318? If not, I will just run one of the pieces I have.
My concern is that the manifold section going into the pipe is a bit smaller than the exhaust pipe. I guess I could cut the pipe down a little to tighten it up before it bottoms out.
So when I put them together, it is not a very tight fit.
The two right side manifolds I have are basically the same outlet size.
Just so you are aware, the factory DS manifold for a '74 is only really different from the 340 you have in that it has the flanges for the heat stove like the 318 manifold.
I had the same 340 manifold you have and swapped to the '74 style so I could get a spark plug boot heat shield.
Doesn't really matter unless you are going for a complete OE look.
received_1347159642330618-jpeg.1715722619
If this build would bring more $$$$$ I would try harder for a near perfect OE look, but the money in vs money out is just not there. It will look really good, and most people won't notice the slight liberties I took. Shoot, the way it is going I will have done all this work for about a $1.00 an hour. Good thing I like doing this stuff because at this rate it is not much of a business model. LOL
These are not for sale pictures are for reference only. I know you asked for 1974 360 but this is my late build 1973 340 car. Pictures are after a quick milling flat. After ported.
note) The spot we hit is very slight looks bad since paint was messed up. But was very slight.
Perfect, looks just like what I have, minus the heat shield tabs. Hmmmm, maybe a little porting is in order!
Took a minute, but it is back to zero. Anyone know if Performance Car Graphics is back up and running? May need to get the speedo decal, or I could just leave it. IDK, still a little rough.
On to the rest of the dash. Took it apart to clean up the plastic lenes. Used a little polish and it cleaned up pretty well.
After polishing
Disassembly
Etched plastic
Polished clean
Looks good. What color/brand paint did you use on the wheels? Thanks!
I have the same brand and color in enamel and BC/CC but I used the enamel paint on these. I was going to use the bc/cc but I wanted to try the enamel for a comparison then I ran out of time. IMO the enamel has a little less flake look to it and a little less shine. I guess a little closer to factory IDK. I added some pics of the BC/CC look.
Enamel
BC/CC
You mentioned cloth electrical tape. I've seen it at either Lowe's or Home Depot. My local Lowe's didn't have it. I did find it at a small town mom & pop hardware store. Most electrical supply houses will have it, and I bet you could get it off Amazon.
Well this is embarrassing! That sweet paint job on the dash using the high heat paint,
NOT so good. Looked good but had no durability. Even fingers left a mark (gas and oil resistant my ***) that would not come off without scratching the finish. Son of a #@$%&
I sanded it back down and used a satin finish this time. Will take pics once it is dry. You can't win if you don't try!
On a positive note, the dash pad turned out great. I know a lot of folks don't like dash caps, but this fit is pretty dang good. I will take the "W".
Color sanding the hood so I can test fit the hood scoop. A little more orange peel than usual but I was at the edge of the reducer window. Be very mindful of this. Anyway, not hard, just time consuming.
START
LITTLE UGLY
FIRST ROUND WITH 1500
STILL NEEDS MORE SANDING
DONE WITH ROUND ONE, might have to do a 2nd round with 1500 again before the 2000. IDK yet
I am trying to figure out the "correct" location for the voltage regulator. I have seen it mounted next to the brake booster, and I have seen it mounted on the passenger inner fender. Which is correct? IDK When I got the car it was located on the inner fender, but this is a transplant engine so I don't know if it is correct and it looks a little odd. The existing wiring harness has it going near the alternator, but I am not sure where this harness came from. Question of the day, "Where is yours?"
AS IT WAS WHEN I GOT IT
OTHERS
HARD TO SEE BUT THESE ARE BOTH UNDER THE BOOSTER ON THE WASHER BOTTLE SIDE
Started on the wiring (forgot to take pics) but I did insulate the roof.
BEFORE
AFTER
Also glued the headliner material over the repairs.
BEFORE
AFTER
Cost for the insulation and the vinyl was less than $40; labor, well we don't count that anymore :(
Prepping the vinyl top for installation. Letting sit out trying to get rid of the fold lines. I really wish they would ship these rolled up. They just don't want to spend the extra money. The dash cap people ship their product in an oversized box that would easily fit a rolled-up top. &*%$#@
ple
Please don't use spray can glue! It is worth the money to buy the DAP Landau Top glue in a gallon, and then spray it with a primer gun with a 1.7 or 1.8 tip. I got talked into letting someone do a vinyl top for me, and they used the 3M spray bomb glue. First time I rolled the car out into the sun, the top wrinkled up and turned loose. I took it to an upholstery shop and they were able to save the top by reglueing it with DAP.
On to the instrument panel. This is not hard to disassemble but you have to "break" the melted plastic connections that hold it all together. When going back together you can use a large dull awl "heated up" to re-melt the plastic back into a holding position. Don't forget to watch out for the small alignment tabs. They would be very easy to break off.
Here are what the holding pins look like after their bond is gently broken off.
Plastic gauge cover installed over pins
Metal plate with instrument names installed over pins and pins melted back into a holding position. Just put the heated awl in the center of the pin and gently push down forcing the metal plastic out and over the metal plate.
Rinse and repeat for the brake/oil warning lights
These are the little tabs you have to watch out for
Do NOT forget to replace this small strip of tape or dash lights will be a little dim and the light escaping will light up your floorboard/back of dash.
Finished
Yup, that is what I used on the headliner and will be using on the vinyl top. A cheap $39 HF works great, just float the adhesive down to the surface.
This glue
This gun
That's the exact glue that I have. I bought a gallon to redo the headliner in my 2004 Dakota quad cab. My gun is an oldy goldy siphon feed that I've had forever. Lacquer thinner will clean the glue out just like it does paint...lol.
Headliner is in! The strong back light makes it look wrinkled towards the back but it is plenty smooth. However, there is a very slight downward bow just ahead of the point where the liner attaches to the rear glass frame. I will live with that since the only time you can see it is from this angle, on the floor looking up, and if you are in that position you are probably thinking about something else!
Slight problem! Too much damage, might not be able to save the bezels. I can try but it doesn't look good. New ones are stupid expensive, so I guess I will try pretty hard. Stay tuned........
