1. Rd2Scamp
    Rd2Scamp Well-Known Member
    446
    152
    Apr 12, 2013
    michigan
    Local Time:
    5:19 AM
    Lol. Its all good. Been cleaned out and sitting for 2 weeks. Put a match in it too and no KaBoom !! And one weld to hold it in place. Going to have a friend thats a better welded then me do it.
  2. Rd2Scamp
    446
    152
    Apr 12, 2013
    michigan
    Local Time:
    5:19 AM
    Put a USB port in the ash tray tonight. Use it to charge my phone for the Bluetooth radio and the Fitech efi handheld.
    • Like Like x 1
    • DusterDaddy
      DusterDaddy sledgehammer mechanic FABO Gold Member
      2,367
      1434
      Apr 21, 2011
      Holmdel, NJ
      Local Time:
      6:19 AM
      That's snazzy, I'll need to do that! Where'd you get it?
    • Rd2Scamp
      446
      152
      Apr 12, 2013
      michigan
      Local Time:
      5:19 AM
      Found it on eBay for like $3. I had to trim it down a little bit to make it fit. Just hit it a few time on the grinder to make it a little smaller.
    • Rd2Scamp
      446
      152
      Apr 12, 2013
      michigan
      Local Time:
      5:19 AM
      Worked on a little side project tonight. Needed someplace to sit drinking a few beers.
      • Like Like x 1
      • Agree Agree x 1
      • ScampMike
        ScampMike Despicable Damn Yankee FABO Gold Member
        34,120
        8889
        Oct 26, 2015
        all Mopar driveway
        Local Time:
        6:19 AM
        what ya got behind that chair there?
      • Rd2Scamp
        446
        152
        Apr 12, 2013
        michigan
        Local Time:
        5:19 AM
        1994 Ford Lightning. 418w with 88mm turbo.
      • Rd2Scamp
        446
        152
        Apr 12, 2013
        michigan
        Local Time:
        5:19 AM
      • ScampMike
        34,120
        8889
        Oct 26, 2015
        all Mopar driveway
        Local Time:
        6:19 AM
        SAAWWEEEEEETT!
      • Rd2Scamp
        446
        152
        Apr 12, 2013
        michigan
        Local Time:
        5:19 AM
        Lol. Thanks. Got her new in 94. Been sitting for 15 years now.
      • ScampMike
        34,120
        8889
        Oct 26, 2015
        all Mopar driveway
        Local Time:
        6:19 AM
        crash victim resurrection or.. ?
      • Rd2Scamp
        446
        152
        Apr 12, 2013
        michigan
        Local Time:
        5:19 AM
        Nope. Just 36k on her. When with fiberglass to get the weight down.
        • Like Like x 1
        • ScampMike
          34,120
          8889
          Oct 26, 2015
          all Mopar driveway
          Local Time:
          6:19 AM
        • Rd2Scamp
          446
          152
          Apr 12, 2013
          michigan
          Local Time:
          5:19 AM
          End game ?? If you mean plans for the future. Its to get it running and street drive it mostly. Track a few times. More track time when kids get older. Should have no problem running 9s but will keep it right around 10.0s. For now.
        • ScampMike
          34,120
          8889
          Oct 26, 2015
          all Mopar driveway
          Local Time:
          6:19 AM
          ah - street brawler - nice! staying white?
        • Rd2Scamp
          446
          152
          Apr 12, 2013
          michigan
          Local Time:
          5:19 AM
          Yes. White. No street racing for me. Just cruising around. Racing for the track.
          • Like Like x 1
          • FragginDale
            FragginDale Well-Known Member
            76
            48
            Sep 20, 2017
            Tacoma, WA
            Local Time:
            3:19 AM
            I just went through this build and it turned out amazing! Gives me even more motivation for my build! Do you still have the Scamp?
          • joshcook81
            joshcook81 Well-Known Member
            216
            67
            Oct 29, 2015
            Georgetown
            Local Time:
            5:19 AM
            What in tank fuel pump is that?? How do you like it?? I’m wanting to go to the Fitech Efi myself and was looking at your post. Do you still have to use the command center??
          • Rd2Scamp
            446
            152
            Apr 12, 2013
            michigan
            Local Time:
            5:19 AM
            I use a in tank pump for a 88-93 mustang. You just need to make a feed and return line fitting on the tank. I didn't use the command center. Works great for my setup
            • Thanks! Thanks! x 1
            • joshcook81
              216
              67
              Oct 29, 2015
              Georgetown
              Local Time:
              5:19 AM
              Did you happen to take any pictures of how you did yours?? Im trying to figure out how I should do this. Any advice is very much appreciated :)
            • Rd2Scamp
              446
              152
              Apr 12, 2013
              michigan
              Local Time:
              5:19 AM
              If I did it again I would figure out a way to put the return line in the filler neck. The feed line I ran thru the sending unit.
              • Like Like x 1
              • Rd2Scamp
                446
                152
                Apr 12, 2013
                michigan
                Local Time:
                5:19 AM
                Not working on the Scamp today but thought I'd share a new rust removal tip that I tried today. These are some suspension parts off my next project, a 68 Dodge Coronet. It was my grandpa's car. He bought in new in late 67 and I got it in 1992 when he passed away.
                I went to Wal-Mart and picked up a gallon of hydrochloric acid for $6.88. I knocked off the dirt and scale with a wire wheel then put the tie rod adjusting sleeves in the acid for about 30 minutes. A good rinse with water and hit it with the wire wheel again. Sleeves looked like the idler arm to start.
                • Like Like x 2
                • DusterDaddy
                  2,367
                  1434
                  Apr 21, 2011
                  Holmdel, NJ
                  Local Time:
                  6:19 AM
                  Nice and clean!
                • Rd2Scamp
                  446
                  152
                  Apr 12, 2013
                  michigan
                  Local Time:
                  5:19 AM
                  Black paint is next
                • QuickDart360
                  QuickDart360 Well-Known Member
                  863
                  239
                  Apr 5, 2014
                  San Antonio
                  Local Time:
                  5:19 AM
                  Isn't that stuff caustic and nasty? But it looks like it works sweet.
