2" drop spindle ?
wireweld
South Dakota
Can I use the drop spindles with 235 60 15 and a 4.25 bs on a 72 Dart?
Will the fenders clear?
Im not so sure. That tire is 26" and a bit wide. Moving it up 2" puts the swing of the tire in a narrower area of the wheel opening.
I think it will be very close.
I installed PST drop spindles. The tie-Rod will be close to the tire sidewall. I had 235 60 15 on 7" rim with 4.375 BS. The tie-rod was 1/8" from tire side wall. I went to a 215 60 R 15 and its okay but close. I plan on different rims and tires next year.
