j par
just flushing him out that's all...LOL...… here is a little research...![]()
Sorry it took so long to respond I was in the 318 taking a whirlwind and when I was done I wiped my 318 with some Whirlwind paper...
Sorry it took so long to respond I was in the 318 taking a whirlwind and when I was done I wiped my 318 with some Whirlwind paper...![]()
We know what your full of.....![]()
Aahhhh pooop!
You claimed to take a 318.... but you said you "flushed Jababa out".... ????318 whirlwind......
Worse than that I've flipped my top!!!!
I'm not lol-ing yet - I'm still in oh crap!! Mode?
Chomped on that dipstick and still has no problem...
Hey I'm going to go make a comment on that old thread I liked it. I like Reviving some of my old cards it's fun...
.Most the pictures I guess I already have but I went and took a couple more to make sure I gave you the right measurements..
First it looks like I used 1 and 1/2 by 2 and 1/2. You can choose your thickness. They were four feet long to start. and I did this filet cut to add more welding surface to the front. At the rear I made three simple cuts and opened up like a mouth to receive the rectangle stock. I shoved it in there and then pulled it forward to wear it grabbed onto the front frame.
View attachment 1715290051 View attachment 1715290052 View attachment 1715290053 View attachment 1715290054 ^^^filet along the dotted line and you will have six sides to weld for strength instead of four sides, it more encapsulates...
I think I had $37 into the Steelyard for a 10-footer that they cut into two 4ft pieces forI th and I had the two footer left over the time now used on a sled deck and have this piece left over LOL
now you know why I preach that you can buy an $89 Harbor Freight welder a $50 helmet it $5 pair of gloves and $37 in metal stock and still not have much into those $200 ones they send to your door that everybody recommend you weld on anyways LOL
First off emergency brake cable!? LOL.
I like how you notched the front to attach them.
Did you move the emergency brake cable? Or did it clear?
Thanks for the pictures and info.
So how far did the channel slide inside at the rear?
Now you're speaking my language!!!Woke up to another inch of snow, still snowing. See what we get...….
Maybe Jaba should have kept that old Yamaha Exciter, and I could have grabbed an old sled of some sort, and we could have dragged them...… LOL
My 1st sled was a '76 Yamaha Exciter. 440 fan cooled. 60 bucksNow you're speaking my language!!!![]()
LOL... Should be ok with these.... nothing pinned here...…Hope the corner exhaust valves stay in that head. LOL
Might get all 8 coming your way with these.....
I guess my current plan is to just continue to work with both Dusters and improve the E.T. on both cars. Tons of areas to improve the performance on each car.Ok, back to building "something"..... LOL (still not sure what)
I got one of the 596 heads ported. About 7 hrs on just this head.
no, about the only swap meet I traveled to was Jefferson, Wis. And I haven't done that in about 4 years. Kind of out of room to store junk. My plan is to close out 1 of my storage sheds by June.It's all about the weather. You going to Indy swap meet?
Getting more snow tonight.... a few more inches... LOLIt's all about the weather.
