Hello there, I need some advice.
I am rebuilding my 273 engine.
Standard pistons with +010 rings.
Comp Cam CL20-221-3 ( Duration 256int./268exh. , Lift 0.447 int./0.455exh.) with hydrraulic lifters.
Original heads.
I am trying to get valve spring pressure close to 85 lb with the .015 and .030 shims.
Should I get over or under 85lb., I can play with those shims a little?
Please give your comments, I know that there is more experience than what I have.
Original heads.
