Is the alternator bracket setup on a 273 v8 the same as on the later 318,360 etc. ? If not , does anyone have a pic of theirs? my 66 cuda alternator is not installed properly and looks like something is missing? Thanks
Anybody using aftermarket valve covers that had a problem with the bracket hitting valve cover where the 2 bolts mount to the head??? I am using M/T covers and it doesnt seem to fit like the pics, i am stumped????
Jake
That "Overkill" of a alternator bracket disappeared after 66. I can see it hitting aftermarket cast rocker covers. The 67 and later brackets should work for you.
There was also a similar complex bracket that went more under the alt' toward the fuel pump where aluminum water pump and dual belts carried alt' and a/c You may not need all that though. Simple 67 type brackets would work. Avail. chromed from aftermarket too. Hope this helps
Mancini and Bouchellon both carry the 67-69 style alt attaching brackets and bolts if you decide to go that way...
Yes - had to file the front edge of the Mopar Performance valve cover to clear the bracket on Jake's 65... Had to do the same to the rear of the driver side cover to clear the factory kickdown bracket as well....
Jake
xLURKxDOGx... if you want, I can machine a nice smooth notch in your valve cover, or neatly machine the "Over Kill" alternator bracket for you... Just "options"...
Clif of Az. :coffee2:
