indian
got a 64 dart gt with a 67 273 in it I have looked on old threads and cant find out how to adjust valves on this. im a novice any help would be appreciated.
I always use wheat is known as "EOIC"
This means "Exhaust Opening, Intake Closing," and works on everything from a 1 cyl Briggs to a V16 whatever
This is how you do this
If the valve lash is specified warm, warm the engine up properly, get your tools laid out, and get the wiring, etc, laid so you can quickly remove a valve cover.
I do one bank at a time, and you can reinstall that cover when done and re-warm the engine again if necessary
So warm it up and remove one cover.
Bump or wrench the engine over until..........
The EXHAUST valve just starts to OPEN and adjust that intake valve.
Then bump / wrench it over until the INTAKE opens completely, and is almost CLOSED and adjust that exhaust valve
Another good way --on V8s which have this firing order-- is "the chart..........."
Measure around the balancer to obtain the circumference, and divide it up so you can mark it at 90 degree intervals
I use a feeler the size you need for the lash, and one about .002" larger. A "go -no go" type deal
thank you for your help. the reason for asking is engine was rebuilt just broke 6000 miles when setting up re-build with shop was asked weather I wanted adjustable or hydraulic requested hydraulic but got adjustable and did not go back for another adjustment on valves. started puffing smoke out of passenger side exhaust,used a qt. of oil in 80 miles no noise go compression do you think oil loss and smoke result of valve adjustment???? thanks indian
shop asked weather I wanted adjustable or hydraulic requested hydraulic but got adjustable and did not go back for another adjustment on valves.
Possible broken ring. A compression test or a cylinder leakage test might be in order.
