273 Help!!!
66VALIANT
ROCKDALE IL
can i use a 318 timing cover pushrods rocker arms harmonic balancer and pulleys on a 273 its a 68 block with a forged crank im puttin a edelbrock dual plane performer on it with either closed chamber 273 heads or 318 heads what cam should i got with thanks
That combo is OK! I would suggest a Mopar purple cam with 282 duration and .480 lift. I have that on a 318 and it runs just fine. But you might check with the combination of weight, engine, rear end, ration size on tires etc before.
