273 replacing solid lifters with hydrolic
barry torren
New Member
tacoma
what do i have to know? alot of people say different stuff.whats the truth? thanks!engine is a 1964
You have to change the cam out as well.
If you're running hydraulic lifters you need a hydraulic flat tappet cam and correct length push rods. If you're still running the factory iron adjustable rockers, make sure your lifter preload is correct as well or things will go bad quick.
hydraulic cam...hydraulic lifters...and pushrods for hydraulic cam with adjustable rockers..
Why on earth would you WANT to!!??
I LOVE mechanical cams, only reason I'm getting away now is that this short block I scored has brand new roller hydraulics, so I had a roller hydraulic cam ground, otherwise I'd be running mechanical lifters still.
Why on earth would you WANT to!!?? I LOVE mechanical cams...
I have to agree, but the easiest and cheapest way is to get the rockers, shafts, and pushrods from any non roller 318 or 360. Buy your cam, lifters, and springs and just bolt it together. Check for interference between the rockers and the springs and retainers.
