273 rockers
david340
okc
Hello, I have 273 rockers on my solid lifter 340. I have been trying to find locking adjusters. I have a few adjusters that are loose and can be turned with no effort.
Thanks
David
I have the same problem on my 340.
Bought Crane rocker arm adjusters and lock nuts part number 99802-16 from Summit which jam the adjuster from moving.
Before you install the adjusters, spot face that side of the rocker on top so the lock nut will lock down flush against the surface of the rocker.
