They will work but they will choke the 340 down. There's a bit of difference in the ports and outlet sizes. They will work but not the best.I’m replacing my 273 Commando engine in my ‘65 Barracuda with a ‘70 340. Will my exhaust manifolds from the 273 fit on the 340?
It has power steering.If you have manual steering the best solution is 60s 340 driver's manifold and 96/97/98 Jeep Grand Cherokee passenger's manifold. You might have to do a little grinding here and there but other FABO members have done it. GREAT FLOW!!!
ThanksWith power steering..yep. Unless someone else has a better idea??
A little off track here but........Here are the results.View attachment 1715424527
Yep especially the bottle neck on the drivers manifold.The design of the early a manifolds is so restrictive i dont think it would help that much.
Isn't that nuts the way they made that! It's flat!Yep especially the bottle neck on the drivers manifold.
It has to be that way to go around the steering shaft.Isn't that nuts the way they made that! It's flat!
