2nd Temp sender location
Hankrebel
Long Beach,MS
318 with AC and stock intake
Stock sender located next to Tstat location
PO installed 3 gauge cluster for volts, oil pressure and water temp but never hooked up the water temp. It has the wire and sender twist tied behind the gauge.
I've looked all over and don't see any port for an additional sender. Is there one?
Or would I have to remove the intake and drill/tap another port into it?
SOoooo, did the previous owner hook up the aftermarket gauge for the water temp gauge?
Or do you want to run 2 water temp gauges?
The stock intake only has one tap for the temp sender.
i dont run heat in my duster put the after market gauge
where the heater hose would go if u want
i dont drive the duster in the winter
Well I was actually able to get the dash put back together with a new speedo cable.
After the rebuild of the cluster, ALL the gauges work!
Including the stock temp gauge. Im going to keep the 3 gauge cluster and just keep the temp sender and line tucked in behind the gauge.
