67DartGT340
I have a 3.23 sure grip in my 67 Dart now, but have been thinking about going to a 3.55 SG instead. Is it worth the change? any comments would be a help.
My previous duster came with 3.23's i switched them out for 3.91's it was like night and day,what a performace improvement it was,as far as going from 3.23's to 3.55's i don't think you'll notice much gain,but i think a good compromise would be to run 3.73's,they becoming a pretty popular gear of choice with a lot of guys...
"Some argue "but 4.10s were street gears way back when"...sure, but highway speeds are MUCH higher these days...I cruise at 75-80 mph just to keep up with traffic around some days, and I don't want the motor screamin to do it...racing is not nearly as important as drivability for me."
Got to call BS on that one. Speed limits were at least as high when these cars were in production, at least up until 1975 or 1976, when speed limits were reduced in a typical government knee-jerk effort to save fuel. Sure, a bunch of earlier cars were built with 4.10 rear ends under them, but they weren't installing 6.95 x14 inch tires with those 4.10 rear ends, either. The bigger circumference of those tires pretty well cancelled out the effects of the slower rear ends.
If you want a higher ratio rear end for quick get-aways, why not bolt up an overdrive transmission in there? That way you can raise all the hell you want, and when playtime is over, shift into overdrive so you can hear yourself think!
why not put the lower gear in, and have 2 sets of tires? Some 26, some 31?
Change the ratio that way.
