3.5" exhaust
72scampguy
Mexico Mo.
Anyone running 3.5"exhaust? My headers are 3.5 collector. Anyone make a mandrel bent x pipe for this or you think i should put cutouts on it and then run 3" on the rest.
There are size horsepower all over the internet but what I've seen the mufflers and bends are what kill power. The smaller tube you can use increases velocity.
Personally I don't like the look of 3.5 under the car and what I'm planning is 3.5" to the mufflers 3.5" mufflers and 3" over the axle with exits at the rear of the tires.
Exhaust cools and contracts the farther it gets away from the engine so tube diameters can get smaller the farther away you get.
I have a big block in the same power range.
I am running 3 1/2" , a slight double twist to clear the trans crossmember on the drivers side, to 3 1/2" bullit roundy round mufflers w/ 3 1/2' spirals slid about 1/2 way in them and welded , then to 3 1/2'' turndowns berfore the axle , fully wrapped w/ exhaust wrap from the headers back " just because I had it ." Don't have any floor bard heat !
I have thot about it , but think it would just be extra weight in my case .
That's certainly a consideration. Performance wise, several years ago we ran a test on a 400hp car with our 2.5" X connected to LT headers and then ran the same exact test with the X-pipe removed. The car dyno'd 10 extra hp to the wheels with the X-pipe on and nothing behind it! So in theory, you might add weight but you might still pickup a little extra in the quarter mile.
That being said, with X-pipes, there comes a point with really big motors where they may not increase your hp. We never tested a 3.5" X versus open headers. Some guys swear they work and some guys buy them strictly because of reduced decibels.
Thanks for the offer. I will be calling you when the time comes. Gotta get that motor off the dyno and in the car first..
505' 'r/b , don't think it would be worth its weight .
How much heavier (“Actual Weight”) can a 3-1/2 be over a 3 inch set up dumping at the rear axles?
Just the facts please....
Don’t know how y’all would even have clearance with 3.5” pipes. I can barely squeeze by with 2.5”. Lol
I’ve been thinking about going with 3” oval pipe... but I know.
I think the thought was to run open headers vs the X-pipe? The difference between 3" and 3.5" back to the mufflers is less than 2 lbs. A 3" X with 3" mufflers from the headers is around 35lbs total.
Just as an fyi, a full 3" kit from the headers; X, midpipes, mufflers, tailpipes, 4 big hangers, 10 heavy duty U clamps, packaging and the box it ships in is 70lbs.
