3.55 65 dart
Road/Rage
KY
Does anyone have any videos of there slant six darts, doing burn out with sure grip rear end?
Im putting a 3.55 in mine just curious to see how much of a difference it makes. :confederateflag:
No video, but i can spin both wheels with my slant with a 3.10 (ford) rear-end. But only if the brakes are on!
3.55 with auto will fry tire holding the brake, my 3.55 with a four speed will fry the whole intersection, with 255 60 15x7. So you should be good! That’s a hell of a difference right there 2.45 and 3.55.
My 340 3.55 rear would burn the plastic 10" Pos-A-Traction tires to the ground if I stayed in it through 2nd gear. Never stayed in it to 3rd. Slant could do it in a light A
I think so too. My slant is performance built. I think I can chirp a tire with a 3.55!
Good I dropped ot off at the builders shop today gonna freshen it up and get ready for install!
I had a 7.25 SG in that before I broke it doing a neutral drop going backwards down a driveway. The 7.25 SG is not as weak as the peg leg sister.
I think its a 2.45 open end...
7.25 rear
Likely 2.94's but one thing is for sure you will destroy the 7.25. They do not like heavy duty work. I have blown out quite a few.
upgrade to a 8 1/4 or 8 3/4, unless you want to destroy the 7.25. The 7.25's are cheap and everyone is trying to get rid of one so you may have an endless supply.
