I just picked up a electric choke Chevy linkage T-Q. Small version.
Whew, dirty lil'thing.
urchinhead said:I've read others, but this should help clue you in:
http://www.bigblockdart.com/index.php/topic,14691.0.html
there is a number on the drivers side rear mounting foot. shown in picture. what is the number? post the number and i can tell you what is came off of.sdolsay said:I have a T-Q on a shelf in my garage, how do I tell what it is(cfm etc) ?
i have numbers that go as far as 1974. i don't see your number in there. iwill guess it is a lean burn model w/ a wire and plug coming out of it. if it is a lean burn then it is probably a smaller model 800 cfm. sorry i can't be more specific on it.sdolsay said:7demon2,
The number on the TQ looks like this:
9388S
55 3
Thanks
more likely the latter......sdolsay said:Here is the carb, it was on my car when I bought it with a stock cast iron intake, I wonder if it was a 318 4 bbl engine they swapped in or if they put a 360 intake and carb on a 2 bbl engine.
