[SOLD] 318-340-360 Fluid Balancer
shatar4
Howell, Mi
For sale is a fluid filled damper for small block Mopar. Non weighted, will work on all LA series '64-'91 engines (non Magnum) engines that are internally balanced. Do not use on cast crank / external balance applications! 7.25" diameter, 1.5" thick. Engraved timing marks from 10 after to 50 before TDC plus every 90 degrees. Chrome finish.
Damper is SFI 18.1 approved to 12,500 RPM. Forged 1025 steel housing and steel hub. Filled with high viscosity silicone surrounded by a nylon ring that allows the iron inertia ring to rotate with engine RPM to dampen harmonics at a greater range for superior performance.
Price is $60.00 plus the ride.
