Looking goodProgress has been slow, due to a bunch of customer work, but "rodney" is finally assembled, and primed. Hope to test run and break in the cam this week.
Good things take time so they say and you have other important things to do like make money to pay the light bill. LOLProgress has been slow, due to a bunch of customer work, but "rodney" is finally assembled, and primed. Hope to test run and break in the cam this week.
Perfect, and I'm glad you didn't go full tilt. 90% of the guys out there would be plenty happy with what you are building.Perhaps, but it will be for sale at the conclusion of the dyno testing, so not a "set on kill" type build.
I can see 400 horse there. I'm guessing 423. LOLYeah, so as a recap, I made a few minor changes, to keep this a simple "everyman" build. That means out of the box heads, no exotic machine work, no heavy milling of heads ect. Here is the basic rundown as it ended up.
Early 70s 318 block .060 over
Cast 340 crank turned .010/.010
Scat I beam rods
Icon forged flat top shelf pistons
King bearings
Melling oil pump
Comp solid flat tappet cam
Liberty performance bushed rockers 1.6
AFR heads BOX STOCK
RPM air gap intake
Milodon stock type oil pan
ARP main studs
The compression is lower than I wanted, it measures out 9.9-1 but again, bolt together simplicity
If and when I put together my roller block teen with the Speedmasters, I would be happy to see 400 horse on the dyno screen.The goal is to HOPEFULLY make 400 HP or so, but might not have enough compression and camshaft, we will see.
Remind me of the cam specs please. I think 400 is a stretch, unless it has a fairly healthy cam.The goal is to HOPEFULLY make 400 HP or so, but might not have enough compression and camshaft, we will see.
236/242 .502-.511 but using 1.6 rockers, should be upper .520s on liftRemind me of the cam specs please. I think 400 is a stretch, unless it has a fairly healthy cam.
Ye of little faithRemind me of the cam specs please. I think 400 is a stretch, unless it has a fairly healthy cam.
I went 11.50’s-60’s with that detuned( ran good bit smaller cam) on that enginemasters 477 horse 30 over 318 at 3400 pounds with a Chinese dual plane. Cam was 231-237 vice the 247/247 cam it was run in the competition with. It was 10.44 to 1.To be honest.....
That menu looks better than the 365horse 327 chevy by quite a bit. The chevy was probably good for an honest 300-325 at the crank, so I can easily see that teener somewhere between 375-400.
And that's probably high 11s/low 12s in a light a-body, depending on prep/gear/converter.
(Wallace says 11.80s with 380hp at 3200lbs.)
Richard Holdener did replicas of the high output 302/327/350 and they all dyno'd about 355 hp in dyno trim with headers. The heads where holding those engines back.To be honest.....
Thank you. That’s a nice grind, I’m not sure it will push the torque up high enough to make the 400hp but I’m hoping it does for you. You’ll be damn close I think.236/242 .502-.511 but using 1.6 rockers, should be upper .520s on lift
Or Honest Abe. Same sameYe of little faith![]()
You could be right, it all depends how well the AFR's respond, I think it will at least hit 400 hp, time will tellOr Honest Abe. Same same
I’m just glad someone is doing it and unbiasedly (is that a word) posting the results. Data is data and it will go in the memory bank.You could be right, it all depends how well the AFR's respond, I think it will at least hit 400 hp, time will tell![]()
Again, so roughly 300-325 in a car with manifolds, alternator, water pump, exhaust system and 180 degrees.Richard Holdener did replicas of the high output 302/327/350 and they all dyno'd about 355 hp in dyno trim with headers. The heads where holding those engines back.
100%I’m just glad someone is doing it and unbiasedly (is that a word) posting the results. Data is data and it will go in the memory bank.
