318 build with dyno session
Stock stroke or 4" stroker?
  • Stock stroke 318
    Votes: 48 88.9%
  • 4" stroker 318/390
    Votes: 9 16.7%
  • Total voters
    54
  • Poll closed .
I am kinda curious now how a flat tappet vs. roller performs with the same specs..
The roller should beat it until the valve train goes chaotic.
The roller and FT lobe should not be the same, even though the numbers LOOK the same.
The roller, once the valve is moving should have far more area under the curve than FT lobe.
You can smack a FT lifter pretty hard right off the seat, but you are limited by lifter diameter how fast you can move it after that.
The roller can’t take that hit right off the seat, but once it’s moving you can throw as much valve speed at it as the valve train will take.
Valve speed, like. RPM is your friend. Until you can’t control it.
Yeah, just did a search and read a bit, was just surprised that i couldn't find a side by side dyno comparison.. learned a bit though
You can skip to 10:45 for final dyno results. They have the same @ 0.050" but the roller has .050" more lift.
https://www.hotrod.com/news/engine-masters-ep-16-tests-roller-vs-flat-tappet-camshafts-and-lifters/
There also is out there (somewhere) a 383 mopar cam shootout where they compare a milder and wilder flat tappet, then a milder roller and it basically gave the best of both of the flat tappet cams.
yeah.. for me not wanting over 5500-6000 a SFT would be fine.. i just don't wanna be another flat lobe horror story.. when i was a kid we would just slap cams in and run them, had no idea bout break in or anything.
Exactly. What we didn't know didn't bite us in the azz back then. I think cam cores were much better then. And, a lot of cams had duration and not much lift. Stock springs and valvetrain worked well.
AHH.. that's a very good point... valve springs? uhhh yeah.. it has some :) as kids we used whatever was in the head with 60k miles on em.. probably made the difference.
No flat lobes here hopefully, I reface every flat tappet lifter I install, and knock on wood, no flat lobes so far. I firmly believe the issues are with the machining of the lifter faces, not the cam cores, not the hardness, allways the lifter. In my experience.
NC, any tricks for getting the dipstick tube outa the block? or heat and swearing? haven't tried yet but betting it's not gonna be fun..
Well, what I use is my dowel pin puller, i put a pin in the end, clamp down with the puller and slide hammer it out
k.. will figure it out.. not sure if i should try to remove the cam bearings or let the shop do it.. should probably ask them :)
I like to do all i can... doens't look too bad to do.. worst i do is waste a set or 2 of bearings :)
i feel ya on that. i just look at it from a purely economical level $60 for the shop to knock 'em in (while the thing is already there getting hot tanked) vs dropping $80 for two sets plus the frustration.
also if you don't have the johnny kick *** tool, like the real deal one of the good ones you're all but gar-un-teed to mess up at least one. and hopefully not the same one twice!
What’s the compression ratio with the parts you have?
Are you willing to cut the heads for a decent cr number?
Do you provide that service for hire? If so, what's the cost to have a new set refaced? It's pretty sad that it's even needed these days.
Valve Lift Intake:
 .525
Valve Lift Exhaust:
 .530
Duration Intake:
 280
Duration Exhaust:
 288
Duration at 050 Intake:
 227
Duration at 050 Exhaust:
 235
Lobe Separation:
 109
Intake Centerline:
 103
Hyd Roller if it matters..
Just my opinion but I would like to see duration at
050 at 237 and 245 with lift at .560 if it fit the piston.
Compression is the key here 10.5 minimum.
well.. at the time i was trying to get torque out of the motor plus it will rarely go over 5500-6k.. the cam works really well, the idle is a bit much bit runs great..
I've got an old valve that works good as a drift pin to knock the tube out from the inside if the pan is off. Perfect size to knock it out without boogering up the bottom of the tube.
ahh ok.. i wasn't sure if there the tube was inside a recess or just in the hole.. that will work. My block is so dirty it's crazy, gonna powerwash it this weekend..
Sorry for all the chat in your thread NC...
Do you have an opinion on the comp dlc coated lifters?
