318 build with dyno session
Stock stroke or 4" stroker?
  • Stock stroke 318
    Votes: 48 88.9%
  • 4" stroker 318/390
    Votes: 9 16.7%
  • Total voters
    54
  • Poll closed .
Oh i see.
Yeah that seems quite likely.
Not that it’s a huge difference but I think the AFR site lists the valves for their heads as 8mm.
They are indeed 8mm, in fact the valves, retainers and springs are all LS based parts. That's actually a plus as far as I'm concerned
Yes, but I meant the bare casting was the same.
I don't know where they come from but I recall that NC Engine Builder said that my ProMaxx 171 heads had a nicer short turn than the typical SpeedMaster. So I don't believe the SM and PM are the same base casting, and PM does all their own machining. I would also assume that the new AFR is a unique base casting as well since the port as cast is different in size.
8MM = roughly 5/16 in.
Yup ^^
8mm = .3149"
5/16 = .3125"
For those that are curious, metric to english conversion is x divided by 25.4. 8mm / 25.4 = .3149".
English to metric is x times 25.4. For 5/16 it would be .3125" x 25.4 = 7.937mm.
I used to work for a Swiss company and all our machines were metric and when training US employees on them, I became very adept at converting units back and forth.
So after the successful cam break in, I needed to remove the oil pan to fix a leak, so i thought I'd peek at the bearings, and they look perfect, actually looks like it never ran. Coated King bearings look perfect. Maybe I got it cleaned pretty good before assembly!
Well, should we expect any less out of you? Nice job.
397 HP.
6400 Rpm
It should spin up even higher than that though
Sounds like a good combination and an excellent builder .
Tommy
Pi multiplied by 130.0, that's my guess for horsepower.
