318 cam upgrade
That's why I recommended the Summit 6901. It's the same thing.
The melling 23203 is 444 465 lift IIRC
It's a a little different. Depending on measuring levels, the summit cam may have faster ramps if both are advertised from the same lift point
I agree with the Melling comment. They can make some respectable power with other bolt ons. It's a good grind for the dough.
I love these threads. A bunch of suggestions for cams and generally in the same ballpark.
I sold the used 214/224 cam out of my 340 years ago. Wish I still had it and would have put it in the 360 for the Aspen R/T. Oh well.
I love um too but generally, the advice either falls on deaf ears or gets lost with gurus always saying there's something "better". News flash. There's always something "better". LOL
seconded-ed
good cams at a good price, decent power and they don't beat up the valve gear too bad.
some of the melling ramps are pretty lazy. also, i know some of their older grinds are measured like the old MP stuff-- only they know how and where they start!
short duration and .440-450 lift.
This is the one I was thinking of. Good luck findin it.
268°/272° Hydraulic: P4452761​
Intake Duration, Nominal​
268°​
Exhaust Duration, Nominal​
272°​
Intake Duration @ .050”​
228°​
Exhaust Duration @ .050”​
231°​
Intake Lobe Centerline​
108° ATDC​
Exhaust Lobe Centerline​
112° BTDC​
Lobe Separation Angle​
110°​
Overlap​
50°​
Intake Opens​
26° BTDC​
Exhaust Opens​
68° BBDC​
Intake Closes​
62° ABDC​
Exhaust Closes​
24° ATDC​
Intake Lift​
.450”​
Exhaust Lift​
.455​
This is the cam i would run
