[WANTED] 318 Carb (non smog) and manifold (67-69 dual plane)
I have an 85 that still has a lean burn carb on it.
A '79 to at least '88 intake will interchange with yours. I don't have any info for anything later than '88, so, there may be later ones that work too. I would have the intake magnafluxed to check for cracks before buying and/or installing. The main areas I've seen problems are in the webbing between the two barrel openings, and in the EGR port.
Assuming that you're just putting together a driver and not looking for high RPM performance, I'd get a '67-9 273/318 dual plane intake manifold. Those don't have the crack problems that the later intakes have. You'll want an earlier non-smog carb and the matching choke assembly too (if you want to use one).
