Depends on what your expecting your car to do. From a power stand point there is no advantage to running 318 heads on a 360. Don’t expect your motor to make any decent power past 5k. From experience I have 318 heads on my 360 currently and it runs really good for a cruiser, from idle to 4500rpm she’s in her happy place. I do have j heads I’m working on to replace them. Those 318 heads are your limiting factor on power, you have a decent cam, headers, and all the rest. I don’t see those 318 heads able to support efficiently unless they been ported and opened up to larger valves, plus the guides may need to be machined down for that cam. I guess what I’m saying is there is nothing wrong with running them if you are building a cruiser, on a budget, or whatever. But if power is what your after get the larger port heads. I would take flow over compression for power when giving a choice between the two. Did you use stock pistons for the rebuild?
