Stormy69
Dusted
you may have the correct firing order but do you have the #1 wire going to cylinder #1. if it has ever been messed with dont trust that #1 is where it should be on the cap. pull the cap off and put the engine at tdc on the compression stroke and verify the rotor is pointing to number one on the cap.
