moparmat2000
Hi Y'all,
I am in the process of tearing down a 1974 318 for a rebuild/ mild hop up. I pulled the timing cover, and there was a factory chain setup with an aluminum cam gear with nylon teeth moulded to it.
Ford did this about the same time, they called it a silent chain. This one had chipped teeth. Obviously i plan on using a double roller chain and sprockets, and a magnum chain tensioner.
But did the nylon setup really keep it that quiet. Somehow i doubt it. Just seems like a cheap **** way to do something if you ask me. Thought only Ford was stupid enough to make cam gears with nylon teeth.
And no the slant 6 dizzy gear dont count.
Matt
Matt
