SSG_Karg
Enhanced member
Ok, so this little project is on the verge of snowballing into a giant pile of wasted money. All comments and advice are welcome. Here goes,
Last weekend I yanked the 318 out of my Duster to replace a leaking rear main seal, replace timing set, and give it a general once over and cleaning. Upon disassembly, I decided to calculate just how low the compression is. I discovered that the flat top pistons, most likely Sealed Power 285ap, are an abysmal .100" down in the hole. Couple that with the '587' casting heads with about 70cc chambers and the Comp XE268 and it is no wonder it was a lazy turd below 2500rpm.
So my question to you is; what is the cheapest and easiest way to gain a little power out of this little nugget?
What I've considered so far is:
1). to swap in a set of KB399s but I don't know if that would require a balance job.
2). Leave current pistons in and have heads shaved .050-.060" and run 1121G head gasket
3). Leave pistons in, leave heads alone, and install Hughes Whiplash cam.
It seems any of these options will cost close to the same, around $3-400 and I'm not willing to spend any more than that. I'm building a W2 stroker that will be taking the place of this little 318 eventually.
Current specs are:
72 Duster probably 3300lbs
4 spd, 3.91, 28" tire
74 318 .030 over
stock crank turned .010/.010, stock rods
Flat top cast pistons w/ 4 valve reliefs (believe they are sealed power 285ap but not sure)
2.02/1.60 J heads with 1.6 rockers
Comp XE268
Torker 340, Holley 650DP
Current combo has gone a best of 13.6@99mph but I'd like to get into the 12s with the teener before I swap in the big stroker.
What would you do?
Current specs are:
74 318 .030 over
Comp XE268
What would you do?
