Rumble; feel free to skip to the bottom line.......lol.
Car will have an A833 O/D box, and 3.73 gears. 68 340 exhaust manifolds and dual exhaust.
I did just about exactly that, except no stroker. The teener was my winter motor for 5 years running.
All I did was; oil pressure test,compression test, cooling system pressure test. She passed them all. I put a 340 chain kit on it,no tensioner, a TQ and intake, and used the TTIs from my summer screamer;that's all.No cam.My engine was a 73; is actually, I still have it,now in another project.
I ran that combo with 4 or 5 different transmissions, and many different rears. One of my favorites was the A-998 with the 2.74 low-gear and a 2800TC, and 3.55s. Well, there was no loser combo. I ran it with the same exhaust as was on the 360 summer engine,namely;TTIs and dual 3" all the ways with an H-pipe. You have got to try that! That 8/1 engine sounds soooo mellow at full-song, thru dual 3s.
Anyway,
the point I'm working up to is this;try to resist the urge to throw a cam in it.That 8/1 engine really isn't an 8/1. The cam that's in it makes good cylinder pressure, and so the low-end is pretty good. At WOT and after about 3500 it makes reasonable power.But;
That od trans has very wide ratios, wider than anything you can bolt on there, short of a trans from a grain-truck. 3.09-1.67-1.00-.73od, with splits of .54-.60-.73
Now, if you put a bigger cam in her, she will lose cylinder pressure;guaranteed. And that will show up as a soggy bottom end. Your 3.73s will help get you thru that
If you put a 262 (a typical choice);for low-ET she will want to be shifted at 5500ish, making the drop on the 1-2shift to 2970. That would be a powerband requirement of 2530. Teener can't hardly do that with the meager cylinder pressure it's gonna make. So it will feel soggy. But if you shift it at 3000 in cruize-mode, the Rs will drop to 1620, and again, the meager cylinder pressure will mean that you have to open the throttle a lot further than necessary, just to continue accelerating from the current 21 mph to cruise speed in second.
I just can't stress this enough; with that od trans, please stick with the factory cam.
If you had a lighter car, like an early-A, then you could maybe get away with a mild cam, but the 2nd gen Barracuda is the tank of the As, with p/s, p/b,aluminum top end and wheels,plus full interior, mine weighed in at 3450 with less than a half tank of gas. This is 10.85 pounds per 318cube, pretty mundane. The early As are about 350/400 less so in them, this is 9.59, fully 12% better. That's like adding 38 cubes right there!
Heres a quick comparo;
This is a stock teener with the 240/114 cam in it
Static compression ratio of 7.8:1.
Effective stroke is 2.89 inches.
Your dynamic compression ratio is 6.93:1 .
Your dynamic cranking pressure is 132.46 PSI.
V/P (Volume to Pressure Index) is 110...............................................
110VP
And here is the same engine with a 262/110 cam
Effective stroke is 2.72 inches.
Your dynamic compression ratio is 6.58:1 .
Your dynamic cranking pressure is 123.66 PSI.
V/P (Volume to Pressure Index) is 97.................................................
97VP
Notice the drop in cylinder pressure, and that the VP has dropped by 13.4%. That's like the engine just shrunk by that percentage. That's why the teener feels soggy on take off. To get it back, you will have to slip the clutch out and rev it it up to where the torque is that same percentage higher. Ideally the compression needs to be brought up,usually with pistons.
Read about VP here;
V/P Index Calculation
Here is the same 262 cammed engine, now with the cylinder pressure brought up;
Static compression ratio of 9.5:1.
Effective stroke is 2.57 inches.
Your dynamic compression ratio is 7.59:1 .
Your dynamic cranking pressure is 149.29 PSI.
V/P (Volume to Pressure Index) is 111..............................................
111VP
Notice I had to bring up the compression ratio to 9.5 to get the 111VP. So now the bottom end feels about the same as the stocker. This will make a very nice teener; plenty of torque, good power, lots of rpm, yada,yada,yada.....
With a 262 cam,the power peak might be up around 5000/5200, which with 3.73s is about 44mph.The starter gear is pretty good at 11.53;so, you don't have to slip the clutch much to get moving. But then with the bigger cam, you have to drive thru the soggy part which ends at somewhere between 3000 and 3750 where the torque peak will likely occur. Now you're starting to make power;26mph. At about 40 you're gonna shift.And the Rs will fall to 3100, back into the top of the soggy territory. Second gear will now get you about 65mph@5000.
So really,
The point I'm working up to is this; with this od trans and a 262 cam, the power is from 26 to 40mph, and again from 48 to 67mph, with the 3.73s
So let's talk automatic for a bit;
Say a
factory stock teener, but with an A-998 automatic, and with the 2800TC.
2800 is about where the stock teener makes it's maximum torque. So you have the potential to blast off right off the line. With a 2.74 low gear and the 3.73s, your starter gear is 10.22, about equal to the stock A904 with a 4.17 rear gear. But wait; the TC has a hydraulic torque multiplication factor, that, on the line might be as high as 1.2, making the 10.22 climb to an instantaneous high of 12.26, and that is really blasting off!.But don't get excited, this multiplier rapidly falls off to perhaps 1.05 at about 3 car-lengths out. By now, the engine is well on the pipe,the secondaries are open,and she's pulling hard.And will continue to it's powerpeak at around 4400, and you will want to shift no sooner than 4700/4800 (5000 in my case), so 38mph.(put some springs on it) So it has been making good power almost from the get-go to 38 mph. So now comes the 1-2 shift and the Rs drop to 2700,oops 2800 plus slip, and you're back in the ballpark pulling hard,and second gear is good to 60=4500ish,about where the power-peak is.
And so the factory teener is making less power than with the earlier 262* cam, but the delivery is now from 3 lengths out,to almost all the way to 60/65mph; about the quickest way ever,to 60mph,with a factory teener,lol.
So the point is this;all other things being equal; the highest average power put down, wins,especially in the fun department.
I fabbed custom bracketry to put the automatic floorshifter up through the 4-speed hole, with no gear indicator. Yeah, I counted clicks,lol.
I put studded snows on it, and there is just no way to tell you how much fun this little winter engine was.
The only other combo that came close in fun-factor was with 3.91s and with the od box and splitting the GVOD. With this combo the powerband requirement was just 1050rpm. That little teener scoots pretty good when on the pipe; ALL the way. 4.30s were pretty good too, but a little too much starter gear for me.
So, it might sound like I'm
trying to steer you towards the A998, and I am. I'm a die hard stick-man since 1970. But this combo will be way more fun with the A998/non-lock-up and a 2800TC.No comparison. Especially with the 3.73s. Teeners really like a starter gear of about 10/1, and 2.74 x 3.73 = 10.22 BadaBoom!
Ok one more; stock 360 2bbl, with 252/112 cam
Static compression ratio of 8.0:1.
Effective stroke is 3.02 inches.
Your dynamic compression ratio is 6.91:1 .
Your dynamic cranking pressure is 131.95 PSI.
V/P (Volume to Pressure Index) is 120.........................................
120VP
Or this one, factory 360 with a teener cam
Effective stroke is 3.13 inches.
Your dynamic compression ratio is 7.12:1 .
Your dynamic cranking pressure is 137.27 PSI.
V/P (Volume to Pressure Index) is 130.........................................
130VP
you can put that 833od trans on this and drive it like a teener,lol. 130 is gangbusters. You could probable drive that with a one speed,lol.
I know this is a long rambling post,but that's the way it worked out.......lol
