It has electronic ignitionLost the points
don't smell gas i messed with the wiring and after it cooled off it fired right upDo you smell gas....?
Check the needle and seat, maybe flooded it.
Wait. You said driving down the highway it died...if you have no spark...and you're cranking it over depressing the peddle ...you should smell gas if the fuel pump I working.
D
Could also be the pick up in the distributor, seen them go bad when hot.Ignition Module.
Well if it starts and idles for a while, that's not likely to be a ballast. But that is not what post #1 indicates. Post #1 definitely points to an overheated ballast.Or an overheated connection somewhere in the primary wiring. Or an overheated coil.Yeah, the easy stuff. From what I recall, the OP says it starts and runs for a while, then dies. Would a ballast do that? My experience with ballasts is that #1 you carry a spare in the glove box, # 2 when they go, they go, they burn out causing an open in the circuit. The car will start, when you release they key to run, it stalls. Reading post # 1 this is a possibility.
I think it's time to check the fuel filter and then the fuel pump and pick-up tube. Are you getting continuous flow of fuel to the carb?
