reddishdsb
- Joined
- Jul 15, 2006
- Messages
- 244
- Reaction score
- 14
Are some years better than others? Found a 66 guy wants 300.
He said it was a '66. It's a poly, unless the guy mistakes if for a 273.Agreed. Just make sure it is not a Poly 318 and it is indeed at least an LA engine. (Or Magnum)
$300 is fine it if is in excellent condition but not for well used.
As far as actual year is concerned? None are any better in general to get over another BUT, new (or lower mileage) is better.
The Magnum engines are really well for the fuel injection does really well for longevity of the engine and it's cylinder wear. Just realize it oils through the pushrods and not through the block like an LA.
Don`t you think he would be further ahead with a 360?
Personally, I don't use 360's. I've been keeping 340's around so I didn't have to.
Didn't have to go with the extra cubes?
Lol, why would you want to to anyway
Yea, I can read, just adding in something so there is no mistake. It's that borderline year and there are many people who don't know jack selling something to someone who don't know any better.He said it was a '66. It's a poly, unless the guy mistakes if for a 273.
Hanging out with "stroked340?"Don`t you think he would be further ahead with a 360?
Magnum,if it's possible... 340 flow number heads,actually good compression,and a good daily driver roller cam...poly 318........ not much out there for it, and what is out there is expensive.
I would suggest an LA 318 (1967-1991) or Magnum 318 (1992 and up)
A 318 is just a detuned 340 with a slightly smaller bore.
Or a better description is that a 340 is just a hopped up 318 with a larger bore.
