[WANTED] 340 360 Engine mounts 1972
Eagle771
Member
marengo
Rating - 0%
0   0   0
ISO Real 340 360 Motor mounts 1978 360 going into a 1972 Dart. I will even take specs on them and have them made.
Mancini Racing gets them from Schumacher and both are out. Ebay show 318 360 and 340 this does not work (no trust here)
I have a set of 273 mounts does anyone have specs on the spacer till i get the proper pair.
Thanks for any help, trying to install
Marengo IL
Marengo IL
The 318 mounts are different from 340/360, I would be cautious about buying the ones off of ebay if you aren't sure of what applications they are for...
273/318 have a different spacing between the ears of the left side motor mount than the 340/360 engine mounts...
The right side motor mount is the same for all four engines 273/318/340/360....
$150 shipped
I will check today, I'm pretty sure I have a set off of a 360 that I put in a 70 Duster. If I do they will be dirt cheap
