340 4 barrel and 340 6 barrel: were they really UNDERrated?
I have all of it if anyone wants the whole thing
So, with 3.23's and stock converter you won't optimize the math. 92 mph with an optimal 60 ft would get you that. So maybe a 3600 stall and 4.10 gears w/slicks. The way your car is set up, I'd say 92 mph should get you high 14's to 15 flat. Most car that aren't bracket cars won't reach that math.
My Duster ran 105 mph @ 12.8's. Math says I should be running 12.5's. I too have 3.23's with a stock converter. It's hard to hit the math without a great 60 ft time for the combo.
BUT, it appears to show that I was making "typical" 340 power with 8.5:1 compression and no special tuning. I was also running a stock '69 383HP AVS as the original 340 carb is still worn out in the throttle shaft bores.
Most 1968-1972 340 cars tested back in the day would run between 96-98 mph. The 1973 340 generally ran about 94 mph. Granite, your 92 mph would go up a little if you had traction and didn't over shift. You might hit 94 mph with all that corrected
Oh no. Are you sure? 8.25 is lighter, so I'll keep the article
:rofl::rofl:
It says right in the text,....."Anecdotally", I'm talking REALITY..and if You'd have taken the time to read the link You were provided, I weighed both of them, same scale -0-'d out, same floor, they are literally stacked together atm. The 8.75" has 4.11's &/a SG, the 8.25" has open 2.91's, and they weighed nearly identical, add a thicker high ratio ring gear & SG & the 8.25" may actually be heavier. These are both A-body rears from Dusters.
Funny how now days a normal family sedans are a 14 second car, My Avenger R/T supposed to do mid 14's with it's 3,600 lbs weight. Too bad these 3.6l engines weren't cheap and easy to install in a A Body since there's a ton of them.
Yeah my 2005 Avalon allegedly did low 14's stock at 3,600lbs crazy to think it would eat a 340 Dart.
Yea, great info., but mine is a 4-speed car. It's lighter
My 69' Dodge Dart Swinger 340 registration states the car weighs 2879. It is a 4 speed with 4 way drum brakes/power booster, one fan belt or no ac, no power steering. The 4 speeds have a little extra metal welded to the frame for added strength. Everything else is basic. I don't think they are including the driver. Mine also has the 3M vinyl top, maybe an added 20lbs, which would bring the numbers down to 2859.
Looks good autoxcuda- that's a 18 spline 4-speed. Most likely a little heavier than my 23 spline. Splitting hairs I guess, but I bet the 8 1/4 rear in the 74 is about 30 lbs lighter?
the weight difference between a 18 spline and 23 spline would be a duck's fart
not a chance a 8.25 is 30 lbs lighter than a 8.75 mayyyyybe 10. maybe.
:rofl::rofl:
Read the above article, and others have said around 20lbs. Even 30lbs
it would behoove you greatly and add clarity to your posts if you quoted who you were responding to.
Whenever one crosses that threshold into manhood one of the glaring revelations is that, in fact, there is a large difference between knowing something & knowing what You've been told/read.
Some of Us just can't wrap their head around it.
Those number ptinted on the registration for weight aren't worth the paper they're written on. Pure fantasy land.
Believe Me, nobody was more surprised than Me when I dropped them on the scale, and since I didn't have 4.10's & a SG precision comparison wasn't possible....but the fact was obvious...there's little to nothing to be saved weight-wise.
After looking at them, it made sense. The 8.25" cast center-section is larger by far plus the axle tube recievers, the tubes are heavier than the welded banjo extensions, plus larger 2.5"×10" brakes/drums. The nose/pinion is shorter & the obvious 1/4" less ring gear dia. are the only features that offer up a weight savings.
Like you already said, rear axle weight is a ZERO factor.
At this point anyone building a fast street car or a race car using an 8.75 axle is just nucking futs.
Build a D60 an move on or if you want to burn through extra money build a 9 inch.
Sell the 8.75 to guys that have a wet dream of a light weight axle.
indeed. having lugged my fair share hundreds of yards from the depths of junkyards and recently hustled both an 8.25 and 8.75 swap into two different darts it is glaringly obvious the weight is about enough to make two nickles out of a dime.
A bit of clarification for all. When I say stock asut
produced, everything is optimally tuned. We had
unlimited chassis dyno times. We properly adjusted the
timing curves for power and the carb. jets and accelerator
pump circuits. All original parts as produced BUT very well
tuned with plenty of Dyno time. The alignment, ride height
and pinion angle were all looked at and adjusted. When you
bought a new car back then, everything was literally all over the
place and needed looked at.
The "Beach" Track in Long Beach would actually have near zero
or sometimes even better (Mineshaft) Density Altitude on occasion
and was generally great (Unless Humidity was high sometimes).
We all raced Stock/SS back them and weekly brackets at several different
California tracks most ever week. There might be a possibility that our
skill sets might be a slight bit better than a newer driver.
I am was not trying to brag about anything, just answering the
posters original question to the best of my recollections. I was there
and racing since the early 60s. You can take or leave anything I say.
I live my life strictly for an audience of ONE (He is looking down on all of us)!
Mopar Muscle magazine August 2017:
While looking through this, I ran across this article:
The text of the article stated that with this test engine, they claimed to use the stock cam, stock compression ratio but roller tipped rocker arms…
They show 320 HP compared to the factory rating of 275 on the 4 barrel.
Really? The 68-70 440 Magnum had 100 cubes on the 340 and has been found to actually register between 335-350 Hp despite the 375 HP rating.
Taking it further, they swapped on a 6 barrel induction and scored 356 HP.
Again, really ??
I ask this because it seems exaggerated to me.
I’m building a 1990 360 with compression in the mid 9s, #308 heads, 1.6 ratio rockers and a Hughes roller cam with .544 lift, approximately .100” more lift than a 340 cam. I’ll be running a Holley 750 and 1 5/8” headers but I can’t imagine that I’d be at 376 HP with my combination. Their claims seem too high.
Doesn't seem too out of line to me. Your combo with a decent valve job and little bowl clean up on the heads should make 1hp per cube.
