340 Crank bolt threads issue
Dartswinger70
East Coast
I had recently sent out a crank for polishing. I have it on the bench and my crank damper bolt is going into the threaded hole kind of tight. Are there different threads fort he small block LA engine? I looked at both the bolt and the hole and cant see any damage. I had this crank for years and seem to think there was an issue years ago, but I am ready to use it now and am not wanting to wrench it in there if it is real tight. I learned to stop and ask years ago. Does anyone know the thread pitch and is there a thread chaser out there somewhere? :)
The shop that polished your crank should have a tap to chase the threads. Take both the crank and bolt and see if they could help you.
Tool shops should be able to get at tap but could get expensive.
Could be some dirt and/or rust on the threads of the crank or bolt. Try cleaning the crank and bolt, or try a different bolt. I have thread chasers for the bolt, and a tap for the crank. Should be 3/4-16 NF thread.
All small block Mopar balancer/damper bolts have the same thread. Damage can be caused by trying to install a tight balancer/damper using a stock length bolt and very few threads are engaging. I bought a longer bolt to get it started so more threads were engaged before it started pulling the balancer/damper in.
makes sende, the bolt "starts" but gets tight after say two threads, it doesn't get in there very far. I was eying it up to make sure it was going in straight.
Or use the proper tool. A little overkill for a 1 time use but they may have them available to use at the parts store or you can rent from the rent all.
Clean out the threads, use a tooth brush and brake clean for starters. Don’t use a tap, use a thread chaser.
if your machine shop is nice they can help you.
I bought a kit after 30 years of doing it the wrong way and boy are they nice. You almost need it when building chevies because they don’t have a nice big bolt like Mopars do.
They are slick aren't they!
The stock dampener bolt is just long enough to bottom out in the crank and damage the threads on the tip of the bolt if used to turn the engine over with no dampener installed. When you pull the bolt out it drags those damaged threads across the the crank threads.
I got really lucky and was able to run a tap in the crank and fix it when I did this. Then used a thread file to clean up the bolt threads.
Thanks for all the replies. It's funny how the mind works, I got home last night and was thinking "wait a minute didn't I buy a large size tap and die set year ago...?" I went out in the garage found the set which is a Craftsman set from the days when you could walk into Sears and they had such things in stock, so maybe 15 years ago or so I bought it. The size is 3/4-16 for the crank bolt. I chased the threads, and they were resistant the whole way down as in I had to chase the whole set of threads, but the bolt goes in properly now. Yes, I was thinking the threads were stretched or an impact gun was used etc. but there seems to be an explanation here so. Yes proper tools right?
Taps / dies are for cutting threads.
Thread chasers are for restoring threads.
If you put them side by side, you’ll see the sharp cutting edges on taps and soft edges on the tread chasers...
Talk to a machinist about thread chasers. Just a dull tap. The consensus is use a tap. If it is a quality tap you will not over cut the threads. They laugh at thread chasers. How far out of spec does a tap need to be to cause an issue?
For a one time use, what is the most economical tool to buy that will both remove and re-install the harmonic balancer? This is for a 1965 273, and it does not appear to have threaded holes in the HB. Without threaded holes in the HB, how does the tool attach to it to pull it off?
