340 Cylinder Head vs 318 Exhaust Manifold
dibbons
La Paz, B.C.S., Mexico
My factory 340 high-performance exhaust manifolds are in storage so temporarily I will attempt to use 318 exhaust manifolds. I was not sure whether to use the 340 exhaust manifold gasket (one piece) or the 318 manifold exhaust gaskets (3 piece). What I decide to try first was fabricate a 20 gauge steel gasket with the ports sized for the 318 (top & bottom in photo).
I will probably first try my custom steel gasket alone (without either of the fabric gaskets 318/340) and see how/if it seals.
Please post how well this works! I'm interested in doing the same.
Other thoughts I had: I understand that welding cast iron requires a specialty shop; perhaps send the driver side manifold to get some extra metal welded on which would cover the opening.
I have run early A 273 exhaust manifolds with “72” 340 “J” heads. I ported the exhaust manifolds and used 273 gaskets with gold RTV. It worked fine, no leaks. What head castings are you running?
Nice to hear! I will check the head casting numbers.
I'm running 318 manifolds on a 1968 318 right now. I have 273 manifolds available but they are from a 1967.
It’ll work. I used 318 exhaust manifolds on my 340 after I cut my headers off years ago. Had the muffler shop fab down pipes to my existing collectors and had no issues. I also used a one pc gasket, just don’t remember which one. I will be going back to headers when I get my car/motor assembled.
They should be the same exhaust manifold castings, or the same outlets if they are from an A-Body 67 to 68.
