340 engine isn’t getting enough gas, why?
Discussion in 'Small Block Mopar Engine' started by Dakota Smith, May 13, 2018.
  1. Dakota Smith
    Dakota Smith 1976 340 Feather Duster
    107
    16
    Feb 17, 2018
    Georgia
    Local Time:
    1:53 PM
    In the last couple of weeks my 76 340 Plymouth Duster has been severely lacking in power once I get to 3rd gear. I guess there is something preventing enough gas into the carburetor, but I am not sure what it is. Everything is brand new from the fuel tank all the way to the carb, but the carb isn’t new. When spraying brake fluid around the carb while the engine was running, I noticed air is escaping from somewhere around the carb. Could changing the carb gasket be the problem or do you guys have any other suggestions? Also, the fuel vent line isn’t attached to anything at the moment. It is just open under the hood. I plan on getting a charcoal canister soon.
  2. Mattax
    Mattax Just the facts, ma'am FABO Gold Member
    4,493
    2303
    Feb 7, 2013
    Phila. Pa
    Local Time:
    1:53 PM
    Could be the winter fuel and weather is contributing to your recent problems: see this post
    Carburetor trouble
    • Agree Agree x 1
    • j par
      j par Well-hung Member
      10,558
      3738
      Jul 2, 2014
      Portland Oregon
      View My Photos
      Local Time:
      10:53 AM
      First off I hope the hell you're not spring break fluid around on your motor! I hope it was brake cleaner! LOL
      • Like Like x 1
      • j par
        10,558
        3738
        Jul 2, 2014
        Portland Oregon
        View My Photos
        Local Time:
        10:53 AM
        A fuel pressure gauge would tell you if you're running out of fuel at any certain time or getting too low on pressure.
        • Thanks! Thanks! x 1
        • Agree Agree x 1
        • Dakota Smith
          107
          16
          Feb 17, 2018
          Georgia
          Local Time:
          1:53 PM
          Yes. Haha I meant brake cleaner.
          • Like Like x 1
          • j par
            10,558
            3738
            Jul 2, 2014
            Portland Oregon
            View My Photos
            Local Time:
            10:53 AM
            76 340 feather duster? What you tryin to pull LOL :poke:
          • AJ/FormS
            AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s
            14,861
            4025
            Jan 19, 2014
            South-Central Manitoba,Canada, 900ftelevation
            View My Photos
            Local Time:
            12:53 PM
            If she was going lean in third gear, there would be a lot of bucking and farting and misfiring/backfiring going on. You didn't mention any of that.
            In the absence of drama,Verify the choke is coming ALL THE WAY off:If the choke mech is not coming off, the secondaries will not open.
            After that; verify your timing systems.
            If that checks out, time for a compression test.
            • Like Like x 1
            • Dakota Smith
              107
              16
              Feb 17, 2018
              Georgia
              Local Time:
              1:53 PM
              What?
            • krazykuda
              krazykuda FABO Gold Member FABO Gold Member
              45,304
              10557
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              12:53 PM
              Check your fuel filters....
              The one in the tank can get old and disintegrate... The 'sock' on the end of the fuel pick-up tube is known to break down and clog the tube... Then make sure the in line fuel filter is not clogged either.... .
              • Agree Agree x 2
              • Like Like x 1
              • furrystump
                furrystump Well-Known Member
                575
                319
                Nov 13, 2004
                Local Time:
                6:53 PM
                So its a thermoquad? Is this a stock setup? No 340 in 76 IIRC. It would be 360 I think, but I’m old and forgetful. Pictures always help.
                • Like Like x 1
                • Dakota Smith
                  107
                  16
                  Feb 17, 2018
                  Georgia
                  Local Time:
                  1:53 PM
                  They’re are both brand new, so I don’t think they would be clogged.
                • Dakota Smith
                  107
                  16
                  Feb 17, 2018
                  Georgia
                  Local Time:
                  1:53 PM
                  The carb is a 4 barrel Edelbrock, part #1407. The original engine was a slant six, but it was swapped for a 340 before I got it.
                • lil red
                  lil red Well-Known Member
                  757
                  84
                  Feb 15, 2011
                  south shore, N.S.
                  Local Time:
                  2:53 PM
                  had this happen to me in an aspen R/T, the sock would collapse and starve for fuel...shut the car off for a few minutes, restart then it would work fine for a bit till it happened again....took a while to track that down...good call kuda
                  • Like Like x 1
                  • furrystump
                    575
                    319
                    Nov 13, 2004
                    Local Time:
                    6:53 PM
                    So it falls on it’s face in third gear when you are at full throttle through first and second? Put a fuel pressure gauge on it. NOT a liquid filled gauge. If you still have 5lbs of fuel pressure in third it might be the needle and seat. You can empty those carbs it the motor draws enough. They make a larger needle and seat. I run them.
                    • Like Like x 1
                    • nm9stheham
                      nm9stheham Well-Known Member
                      9,724
                      2158
                      Dec 20, 2013
                      Waynesboro, VA
                      Local Time:
                      1:53 PM
                      Same sized fuel line as was there for the /6? Probably too small.
                      And what fuel pump do you have? Can be bad out of the box or if a straight stock one, running out of capacity.
                      As said, start with fuel pressure test at the carb inlet and watch the fuel pressure gauge as you get to the 'weak' speed. Ought to stay in the 5-7 psi range all the time. If it does, then yo have eliminated the lines and pump and tank and can focus on the carb.
                      • Like Like x 1
                      • diymirage
                        diymirage HP@idle > hondaHP@redline
                        14,326
                        6602
                        Oct 12, 2012
                        michigan
                        Local Time:
                        1:53 PM
                        I had the same problem with my duster
                        Turned out the little "rubber" fuel line that connects the pick up to the hard line had too much of a bend in it and would collapse on itself
                        • Like Like x 2
                        • 12many
                          12many Well-Known Member
                          544
                          672
                          Dec 14, 2016
                          South Carolina
                          Local Time:
                          1:53 PM
                          Are you sure the vent line actually vents? Checked the fuel cap?
                        • rigger3006
                          rigger3006 Well-Known Member
                          646
                          137
                          Aug 6, 2013
                          bc
                          Local Time:
                          12:53 PM
                          liquid filled fuel pressure gauge? whats wrong with them,curious?
                        • furrystump
                          575
                          319
                          Nov 13, 2004
                          Local Time:
                          6:53 PM
                          They warm up and go crazy. The fluid expands and makes the reading fluctuate. I had a liquid filled gauge that while idleing it would go from zero to 10 lbs. back to zero. I had heard about not using the fluid guage. I drained the gauge rock steady at 6lbs. Still use the gauge.
                          • Like Like x 1
                          • AJ/FormS
                            14,861
                            4025
                            Jan 19, 2014
                            View My Photos
                            Local Time:
                            12:53 PM
                            Great tip!
                            If I ever get curious about my fuel-pressure, I'll try to remember your tip.
                          • T56MaxTorq
                            T56MaxTorq Well-Known Member
                            818
                            216
                            Dec 21, 2010
                            CO
                            Local Time:
                            11:53 AM
                            I’ve found very little parts for a 45+ yo car to be new. They are all refurbished and mostly poor at that. Even aircraft parts. Since there are so many variants and aftermarket, describe your fuel system tank-carb.
                            Electric or manual pump? Regulator? Pump cam could be flat or wrong pump, cam, cover configuration. How do the filters look? Some filters you must cut open. Any kinked hardlines? Check carb float level. Tank could be full of sealant chips, you never know.
                            Thats even if this is a fuel delivery problem.
                            Posting a video would help. AJ is right, it would be fuckin pissed off and violent.
