440marv
On a 1971 340 are the oil galley plugs behind the cam thrust plate plugged? Or do i just install the thrust plate with them unplugged?
They came with plugs in them for a reason. If your cam thrush plate is warped at all you would loose your oil pressure. Probably not likely but plugs are dirt cheap why take the chance.
I agree but 1971 did not come with plugs.
are the original owner?
someone else could have been in there....
