dadodgekid
When in doubt... floor it
Just wondering if i should keep the factory windage tray with my deep sump pan or switch too a kevko pan? Anyone know pros and cons? Ive heard i can pick up some power with the kevko... Just wondering. Thanks!
Don't you have anything else that could use that time, labor and money?
Seems like a lot to go through for what you would get out of it.
If it were myself, I'd run the stock pan and windage tray and call it a day. The deep pan is fine as well.
Depending on what I'm doing, a crank scraper is great. Or just overkill, which is how some people go and belittle you for not following.
You want every last bit of power?
Yes, thats what im gunning for. Beside going to a roller cam, no money for that right now... But my car is a pump gas, solid flat tappet at 3300 lbs and a 343ci. Last friday was the fastest yet at 11.56 @ 117. Im trying to get in the high 20's low 30's with the setup i have. Next is weight loss and maybe swithing to a 904. But i appricate the input! It really eats these guys up locally... An old mopar with iron heads and pump gas beats up on these LS cars and new mustangs
What gears are you running? Care to share more of the build?
Sure, 4.56 gear with a 275/60 tire.
340, w-2 head, pocket ported and gasket matched by me lol. .557 solid mopar cam and a 4500 ish stall converter. All in a full steel 74 dart sport
Its pretty tame, idles around 900-1000 and i drive it 15 miles to work atleast once a week lol
Dadodgekid, good work. I now see where your at. Keep up the good work... and Azz beatings! This coming comment is also addressed to YR.
"Oil control IS power!"
And yes YR, I have been to his site and spoke with him. I also agree that any serious driver looking for power and your E.T. Mentioned (seems like as good as a starting point as any and a good point it is,) should use what ever means at there disposal and as there wallet allows.
Also a note to others reading that might not have occurred to you. As the crank stroke gets longer, the speed of the rods are picking up speed. This means more wind. (Windage) The "wind" created can actually cause the oil to go
Up the pan sides, hitting the crank, which slows the crank down costing power. Keep in mind you have a lot of oil coming down from the valley on top of this.
The oil takes a beating and lives a shorter life while costing you power. The oil gets whipped. And if bad enough, it will foam!
IF and when you can;
"Control your oil!"
P.S. A deep pan and a oil cooler is also helpful in longer useable oil life.
This is why the factory used a windage tray. It avoids a engineering redesign of the oil pan with a simple use of a tray and longer bolts.
Yeaaaaaaaa, whatever...... Problems with your thinking....That doesn't really make sense to me. Surely the factory would find it far easier to 'redesign' the pan deeper and use a different pickup tube, than to design the windage tray from scratch and then have to manufacture the complicated main bolts with their corresponding smaller mounting bolts. In fact a deeper pan is not really a full redesign, it is the same, just made with longer sides. Didn't the 318-3 truck motor use a bigger pan with the deeper reaching pickup? I'm pretty certain that the windage tray, which was unique to the 340 engines (the race bred engine) was used for just that, to improve oil control by keeping more oil in the pan at higher rpm, and therefore more in line with the 'performance' breeding of that engine. Wasn't for saving money reasons. Chrysler would not have wanted a deeper pan either for ground clearance issues, everything has to have plenty of tolerance when using in passenger cars.
