[SOLD] 340 short block
moparraceman
mansfield ohio
NEW PRICE 340 short block built in late 68 so could be used in a 69 car 340 std bore block and rods that the machine shop cleaned and checked rods have new ARP bolts i painted the block. has STOCK 10.5 -1 PISTONS ,balancer stock ,front timing cover,comp double roller timing set. also have new rings,rod and main bearings,brass freeze plugs,cam bearings ,and fel pro blue head gaskets pr.fuel pump and water pump ,NO PAN OR PICK UP probably have a windage tray to has the bolts already in main caps even yo there in wrong place lol .ready to assemble with a light hone to the cyclinders pick up ohio price $1475.00
Close date code for my car, can you get the VIN number on the passenger side near the oil pan rail?
Is this still for sale? What would you sell the block for?
Thanks,
J
