bigdemo1
- Joined
- Mar 15, 2009
- Messages
- 838
- Reaction score
- 4
DJV could you give more specifics
chemeleon is it true that the holleys run better sideways?
i tried a few cams with my set up,im currently running a single pattern on a 112 lsa.i ran a dual pattern on a 108 before that,and if power were my primary goal id have kept it.mines a street car though.and the grind im running now has very good manners lol.by the way i have 2 vintage 500 carters if your interested.recently gone thru.i took them off because the accel. pump quit working on one,and im a holley man...no offence.pm me if your interested.I'm gettin' ready to try a tunnel ram myself, for now its a BUDGET build, nothing razzle - dazzle or hi-tech, Its going on a stockish 383, I'd really like to run 2-500 edelbrocks (no offence-I hate holleys).. What would be the best cam and converter choise to try??? rear is a 3.73 locker, figure I'll run tall slicks at the track to gear it down a little.. Car is a 66-valiant straight axle gasser, front whees will be moved forward 8 inches...it should be pretty light.. Any ideas on cam and converter stall???
Running a tunnel ram on the street for anything other than looks is a waste of time.
With that said.... Welcome! Nice to have you here!
Back to your post..... If you want the look, we do have people here running them. Give them time to reply and they should be able to point you in the right direction.
If you want to run one for power.... You will be better off with a conventional single 4 bbl set up.
Are you serious man? Distribution is better(when tuned properly)and were even factory options in the "good ol dayzzzzz................
The post you quoted is almost 7 years old. Not sure you'll get much response.
Another thread for the Monty Python "bring out your dead" video...![]()
