360/410 Stroker Questions
Small Block Mopar Engine
  1. Flying G
    Flying G Member
    20
    1
    Jul 10, 2014
    Knoxville, TN
    Local Time:
    7:35 AM
    Greetings. I'm putting together a 360-based stroker engine with a Scat kit (cast crank, I-beam rods, KB hypers) for street use & I hope y'all can help me with some questions:
    1. What is acceptable deck height variation from cylinder to cylinder? What have y'all seen in your builds?
    2. What is maximum acceptable rod side play for this combo? Various manual/books give .014 to .017. If it matters, I'm using a Melling HV pump. Thanks.
  2. 70aarcuda
    70aarcuda Master Hoader of SBM FABO Gold Member
    15,724
    4263
    Jan 16, 2005
    las vegas
    Local Time:
    4:35 AM
    Has your block been squared?
    If it has not been decked to square it...the deck height can and probably will be all over the place.....
    • Agree Agree x 1
    • MOPAROFFICIAL
      MOPAROFFICIAL FABO Gold Member FABO Gold Member
      6,463
      5412
      Jun 1, 2016
      Beach
      Local Time:
      4:35 AM
      @Flying G
      Side play isnt too important .
      Deck variants of .004-.007 are common.
      Rod lengths can work for or against that.
      It's a stacking of tolerances.
      Measure the 4 corners for deck height and measure the rods to stick the longer rods in the tallest deck reading.
      Or square the block, start over.
      • Agree Agree x 1
      • Flying G
        Flying G Member
        20
        1
        Jul 10, 2014
        Knoxville, TN
        Local Time:
        7:35 AM
        Yes, it's been milled flat/square by a reputable machinist. I have no way verifying, so I take him at his word.
      • 70aarcuda
        15,724
        4263
        Jan 16, 2005
        las vegas
        Local Time:
        4:35 AM
        Did you give him a deck height to cut to?....or did just square it?...
        if it is squared.....probably a few thousands is good...what is important is the front to back number and left vs right number..
      • gregcon
        gregcon Well-Known Member
        407
        327
        Dec 20, 2009
        Local Time:
        6:35 AM
        A good machinist should have no trouble putting both decks within .002-.003 of each other and .002 front to back.
        I haven't measured every rod made in the past 10 years but I'd bet the deviation in rod length (of an aftermarket set) isn't more than .001" assuming you buy the rods as a set. Scat is more likely to be off than Crower, but either way....
        • Agree Agree x 1
        • Flying G
          Flying G Member
          20
          1
          Jul 10, 2014
          Knoxville, TN
          Local Time:
          7:35 AM
          I appreciate the replies. I think my terminology needs refining:
          I know "deck height" is used for a block's crank CL to deck surface distance.
          But my 1st question is about variation in the piston top to deck surface distance at TDC.
          Some call this piston height, but that can have several meanings, too. Thanks.
        • Flying G
          Flying G Member
          20
          1
          Jul 10, 2014
          Knoxville, TN
          Local Time:
          7:35 AM
          If I may ask, what is your theory or experience on this? At what value would you say side play becomes important?
          My only references in this area are the factory books & Larry Shepard's book. He says .017 is max & .020 is start over - oil pressure will be too low & the excessive oil squirted on the cylinder walls will overload the oil rings. It is unclear to me if he is speaking of a street performance engine or a race engine, or if that distinction matters. Thanks.
        • yellow rose
          yellow rose Master Of Insanity
          24,485
          20473
          Jun 19, 2015
          Walking a crooked mile
          Local Time:
          4:35 AM
          You can run .150 side clearance and it won’t make a pinch of shit of difference.
          This is another one of those long cherished lies that get repeated, even by the book writers and experts.
          Rod bearing clearances is what controls oil past the rods, not side clearance. In fact, if I only had .020 I’d be finding more.
          • Like Like x 1
          • Agree Agree x 1
          • MOPAROFFICIAL
            6,463
            5412
            Jun 1, 2016
            Beach
            Local Time:
            4:35 AM
            they are hand in hand if the connecting rod connects the piston to the crank and the crank is "Centerlined in the block"..as you put it..but the deck is taller on number 8 vs number 2 and number one is taller than number 7... then all your pistons and rods could be the same length and they would still be at diff measurements from the deck now wouldn't they...
          • Flying G
            Flying G Member
            20
            1
            Jul 10, 2014
            Knoxville, TN
            Local Time:
            7:35 AM
            Yep, understand & agree.
            I still would like to know how much "piston deck height at TDC" variation is typical or acceptable among the cylinders.
            Or is keeping the volume above the piston the same for each cylinder more important than keeping the heights the same (yes, these are related, too)? Thanks!
          • MOPAROFFICIAL
            6,463
            5412
            Jun 1, 2016
            Beach
            Local Time:
            4:35 AM
            You can have a variation of a few thousands and it's not going to kill the performance of the motor.
            I will say that some of the smoothest and quietest running Motors we're the ones I balanced every little thing. I have purchased rotating assemblies balanced and all, come to find out the rods very just a little...I milled the quench pads, some .048 others .046
            I dialed the chambers in even by cc and material removal on one that was 4 cc smaller than the rest..and milled.
            Port flow all within 4 cfm.
            Quietest, smoothest running most powerful small block I can remember doing.
            Many people commented on it. The .575 solid roller was stock quiet...sewing maching.
            It not the end all, just better balanced all around than most. It's more than dynamic balance..its operational balance that's important as much or more.
            • Thanks! Thanks! x 1
            • Flying G
              Flying G Member
              20
              1
              Jul 10, 2014
              Knoxville, TN
              Local Time:
              7:35 AM
              Thanks for your insight. I'm still in my parts mock-up & measurement phase. This discussion has given me some ideas of what else to check. Thanks!
            • crackedback
              crackedback FABO Gold Member FABO Gold Member
              18,707
              3030
              Aug 7, 2005
              92201
              Local Time:
              4:35 AM
              Unless you have a way to measure C2C on your rods, compression height of every piston and make sure the crank is indexed to a gnats ass, then any variance in deck height, you are chasing you tail for the most part. JMO
              You could mix and match parts which is what we did on Stock Elim engines to get the compression distance evened up. Just have to work with the tolerances you have and being .003 out on an engine isn't going to make a bit of difference on a streeter.
              • Like Like x 1
              • Agree Agree x 1
              • gregcon
                407
                327
                Dec 20, 2009
                Local Time:
                6:35 AM
                I'll scratch that even a little deeper...imagine a guy winning a NASCAR race. He's running in front and clearly has a few more HP than every one else.
                Freeze frame the whole thing....then go take off one of his cylinder heads, mill the block .003", and put it all back together. Un-freeze it. Is he gonna fall back in the pack? Or is he gonna keep right on truckin'?
                My money says he's gonna stay in front and keep on winning.
                I'm all for precision assembly....but I also think too many guys get hung up on numbers without keeping perspective on what they mean.
                I also think precision assembly will, ultimately, have for more to do with how smoothly and engine runs and how long it lasts than total power production.
                • Like Like x 2
                • Agree Agree x 1
                • RAMM
                  RAMM Well-Known Member
                  1,818
                  1734
                  Nov 22, 2010
                  Ontario, Canada
                  Local Time:
                  7:35 AM
                  Be wary of rod length especially these I beams. Also don't let your neighbour (guru) assemble your Mopar stroker because he "built" a 350 Chev once. J.Rob
                  • Agree Agree x 2
                  • yellow rose
                    24,485
                    20473
                    Jun 19, 2015
                    Local Time:
                    4:35 AM
                    That one was down the hole a bit.
                  • Flying G
                    Flying G Member
                    20
                    1
                    Jul 10, 2014
                    Knoxville, TN
                    Local Time:
                    7:35 AM
                    That's awful!
                  • Flying G
                    Flying G Member
                    20
                    1
                    Jul 10, 2014
                    Knoxville, TN
                    Local Time:
                    7:35 AM
                    That's hilarious! Not that he grenaded a cylinder, of course. But we do hav ed to have as sense of humor about these things.
                  • Flying G
                    Flying G Member
                    20
                    1
                    Jul 10, 2014
                    Knoxville, TN
                    Local Time:
                    7:35 AM
                    RAMM, I haven't assembled a small block in a while (got into motorcycle racing for a decade or two), & never one as modified as a stroker, but I'm assembling this one myself so I'll know what's going on inside. I'm taking my time, double-checking everything, & seeking guidance where needed. If it fails, it'll be on me.
                    So, what actually happened to facilitate the creation of your table centerpiece??
                  • Flying G
                    Flying G Member
                    20
                    1
                    Jul 10, 2014
                    Knoxville, TN
                    Local Time:
                    7:35 AM
                    We also have to learn to type on our tiny phone keypads. : D
                  • RAMM
                    1,818
                    1734
                    Nov 22, 2010
                    Ontario, Canada
                    Local Time:
                    7:35 AM
                    Cast 4" crank broke, rod bearings that weren't narrowed, line bore wrong, cylinders tapered, etc........ Lot's of little things that guru missed. Worst part is it cracked the cylinder all the way to the pan rail just about--couldn't sleeve this 340 to save it. It was also numbers matching to his Demon. Expensive lesson. Oh well at least it's not cancer or Covid. J.Rob
                  • gregcon
                    407
                    327
                    Dec 20, 2009
                    Local Time:
                    6:35 AM
                    When you see a rod like that, you didn't just lose a cylinder.
                    My engine? I'd toss every rod, every piston, and heavily look at the block and crank.
                    Nothing gets that wounded all by itself.
                  • RAMM
                    1,818
                    1734
                    Nov 22, 2010
                    Ontario, Canada
                    Local Time:
                    7:35 AM
                    Only thing being kept is the cylinder heads, distributor, valve covers and carb. J.Rob
                    • Like Like x 1
                    • yellow rose
                      24,485
                      20473
                      Jun 19, 2015
                      Local Time:
                      4:35 AM
                      Yeah, that deal trashed his wallet bad. That’s truly sickening to see this. It just makes me ill, knowing this guy got screwed, and knowing that when most guys get hammered that hard, they quit and never return.
