You built it show quality once you can do it again. Just pull the intake.
I will probably suck it up and do that.
I'll be happy to send you a wire retainer. Let me know.That was a PIA and a half. This lifter you could compress it with your finger a good 3/8" of an inch. The rest are still solid and I can't compress them with a punch pushing down. I don't see anything really wrong. The cage that holds the check ball on the bottom, maybe, was not pressed on straight. It fell apart in my hands as I was figuring out how it was held together. I cleaned it out, put some oil in it and it is now rock solid and does not compress.. Once the retainer clip flew across the garage I shut off the lights and opened a beer. I will try to find the clip tomorrow.
I am at a loss on what to do. Ask my buddy what lifters he used and get another one?
View attachment 1716459174View attachment 1716459175View attachment 1716459176View attachment 1716459177View attachment 1716459178
I think I would. Maybe reinstall it without the intake and spin the engine over a good bit and see if it stays pumped up. It would suck to get it all back together and it still tick. If it doesn't collapse after that, I'd call it fixed. It doesn't take much AT ALL for them to get blocked. Whatever it was may have fallen out and you may never see it.I saw the direction it went and I heard the jingling as it bounced on the floor. I should be able to find it. Would you reuse this one? I don't see anything wrong with it and it is not bleeding back now.
Yep, toss it in & give it a go, it takes very little to cause it to fail to seat & bleed off....like RRR said, You may have cleared it w/o seeing the offending trash.I saw the direction it went and I heard the jingling as it bounced on the floor. I should be able to find it. Would you reuse this one? I don't see anything wrong with it and it is not bleeding back now.
Take it apart and clean it/inspect it so you don’t end up right back where you started.Ended up needing to order the gaskets I wanted anyway so I ordered a lifter along with the order.
What brand lifter did you get?Already did and it now holds but I don’t trust it.
MellingWhat brand lifter did you get?
Good choice. Made in USA still.Melling
Think he means the new replacement lifter.Already did and it now holds but I don’t trust it.
I didThink he means the new replacement lifter.
Do you recall what size you used? I couldn't find the right size last time I checked.i took apart and cleaned all the garbage out of the roller lifters in the used 5.9 magnum i just put in my 66 Barracuda. Unbelievable the amount of funk in them. But when i put them pack together i put all internal snap rings from Ace hardware that fit in the groove of the lifter to replace the wire snap ring. I also shot a few across the garage when taking them apart. But it worked great, cost 12 bucks and they are much more solidly retained together now.
I wish i could, i literally took a lifter and my snap ring pliers to the hardware store and tried them till the fit tight. I have it written down in my project log, I'll try and find it when i get home. I had seen a cam company selling them for Mopar lifters in a set of 16, I think it was Crower, i didn't want to for them to get here, so i just went and found some, so i could push on with assembling the engine.Do you recall what size you used? I couldn't find the right size last time I checked.
Thank you. If you can find it, that'd be awesome. Do you recall if they were a metric size? If I recall, they were smack in the middle of the two SAE sizes my hardware store had.I wish i could, i literally took a lifter and my snap ring pliers to the hardware store and tried them till the fit tight. I have it written down in my project log, I'll try and find it when i get home. I had seen a cam company selling them for Mopar lifters in a set of 16, I think it was Crower, i didn't want to for them to get here, so i just went and found some, so i could push on with assembling the engine.
they were metric, I want to say 12MM but i'm not 100 percent sureThank you. If you can find it, that'd be awesome. Do you recall if they were a metric size? If I recall, they were smack in the middle of the two SAE sizes my hardware store had.
